This is an estimate compiled from both powertop’s and the OS’s estimates on battery life and what I have personally observed using this as my daily driver for around 5 months now. If you have some other benchmark utility you want me to give a whirl I would be more than happy to run it and tell you what I get.
Alright I was able to get it around 10 hours as well. Just today I finally jumped ship and got myself arch, with the setup I need, which is quite minimal and some HW acceleration and TLP under gnome I was able to get something like that. Didn’t test it throughly tho
Quick question, does hw-decoding for FFox & Chromium work for anybody? I have tried everything that I could find and still could not get it to work. I’m assuming that having hw acceleration on would greatly help battery life? Maybe extend it by an hour and a half? If not then I won’t bother with it then.
I could edit the wiki on this thread now. Maybe it was fixed at the following timing.
I got this to work with Fedora 35 with Chrome, it does help some, thought it seems some but not all video vendors use codecs that Chrome supports.
See my post below.
Did everything in the post you showed and even more still could not get it to work Although I’m wondering if this is because I’m using ungoogled-chromium instead of the normal chrome / chromium browser. Nevertheless I might just go with the yt-dl/mpv option if I see a significant increase in battery life. Thanks!
Hello just updated my system and found out that I have to remove either tlp-rdw or power-profiles-daemon since they are in conflict. Which one should I remove? Is one better than the other? Thanks!
@Linen If you want to use TLP you should remove the daemon, that is used by gnome to regulate power profiles and TLP can handle that, you just would lose the toggle in the gnome ui
I was investigating how to improve the battery drain after powered off (shutdown).
I found some tips.
shutdown -H -P +0
is better thanshutdown -h now
in a new hardware? - Is the command like
hwclock --systohc --local
executed when doing shutdown? If it is, it might cause the battery to drain when the laptop is off.
Did anyone test auto-cpufreq ? Heard that it’s a replacement for TLP & also does the job of cpu-freq & indicator-cpufreq.
Increase and Optimize Linux Laptop Battery Life here is one example, I’m sure you can find a few more by searching for “auto-cpufreq”
Adnan Hodzic (auto-cpufreq dev) mentioned that it’s a complete replacement for tlp & cpufreq. Caz he merged both of their codebases & automated the cpu governor toggles in the fly.
That might be true for the latter, but it only replaces the CPU-related parts of TLP. If you disable those, you should be able to run them in tandem from what I’ve read. I plan on doing that, as I want TLP to manage the power draw of my wifi card and SSD.
Hello has anyone experienced regression with the newer versions of Firefox and ungoogled-chromium? Hardware acceleration doesn’t work for me now. Currently on Arch 5.16.9, Firefox 97.0-1, and Ungoogled-chromium 98.0.4758.102-1.
Just wanted to add my result regarding power consumption in suspended mode:
10h = 14% drain
i7 1165G7
16 GB RAM
512 GB SSD
Elementary OS 6.1
Linux 5.13.0-28
Deep Sleep enabled (s2idle [deep])
BiOS 3.0.7
Just got hibernate and suspend-then-hibernate working on Ubuntu 21.10 following this guide, and I wanted to share in case anyone else runs into the same issues. I had to add resume
and resume_offset
to my grub and initramfs configs. However, mem_sleep_default
caused a lot of problems for me, presumably because it was already enabled. Hibernate would work just fine, but when I ran suspend or suspend-then-hibernate, my WM (i3) would reload and appear fine for a few minutes, but then crashed. It seemed that the OS wasn’t aware of what was in $PATH
, but I couldn’t find anything useful in my systemd logs that would indicate what the problem was. Removing mem_sleep_default
from my grub config solved the issue.
Works for me, I’m on void, kernel 5.16.11, brave-browser (chromium’s derivative).
I have
--ignore-gpu-blocklist
--enable-gpu-rasterization
--enable-zero-copy
--enable-features=VaapiVideoDecoder
--use-gl=desktop
--disable-features=UseOzonePlatform
flags on ~/.config/brave-flags.conf
And have enabled these options under chrome://flags
Weird, I have exactly the same setup with you and it was working before, but now it’s not.
What error do you get if you start your browser from the cli (in the stdout)?
