Linux Fedora firmware update failed "Not enough efivarfs space" when using fwupdmgr
Hello,
Not so sure I’m at the right place here, since it’s Fedora-related, but the firmware issue is linked to the process found on the Framework instructions page, so I prefer to ask here.
I’m unable to update the firmware “Secure Boot dbx” through the update manager, with the following error :
[UEFI dbx] does not currently allow updates: Not enough efivarfs space, requested 30,7 Ko and got 12,5 Ko
I tried to update firmware through fwupdmgr just like it’s indicated here: Updating BIOS on Linux
But then I got the following output: Not enough efivarfs space, requested 30,7 Ko and got 12,5 Ko
I found some issue and potential clue to solve it here: [UEFI dbx] does not currently allow updates: Not enough efivarfs space - #4 by yurislnx - Fedora Discussion
But the thing is my BIOS is up to date, and I don’t know how to “Manually updating bios firmware (not supported via fwupdmgr)” precisely. So before doing anything out of my reach, I would appreciate if anyone here can helped me, maybe someone face the same issue.
Thank you in advance for your guidance.
Details:
OS : Fedora Linux 44 (Workstation Edition)
Hardware: Framework Laptop 16 AMD Ryzen AI 300 Series with AMD Ryzen™ AI 7 350 w/ Radeon™ 860M × 16
Linux Shell: Linux 7.2.9-201.fc44.x86_64
BIOS version: 04.01
See thread/workaround in FW’s firmware issue tracker.
Edit: Resetting BIOS to defaults seems to do the trick, IIRC I had to do the same some months ago.
Thank you! Resetting Secure Boot to defaults did the trick indeed.
