I set the low battery warning to set off at 30%, when it drops it should decrease the screen brightness to 1%, it worked for a while (3/4 months) but now the brightness drops only when at critical level (automatic when at 1%).
It now says that the battery health is at 70%, I hope its some wrong readings because I just got this laptop (march 2026).
Mainly I am worried about the low battery behaviour, if it keeps dropping to < 1% the battery health will degrade faster and faster, I always try to keep it between 30-80.
The battery health problem is more a concern, after charging the laptop it got back up to 100%, maybe it was just a wrong reading.
Actually, discharging to a low percentage gives less wear than charging to a higher percentage i.e. wear level 50-100% > 0-100% > 0-50%. The “center” should be 20-70% rather than 30-80%. However, if the battery health is declining rapidly despite you keeping it between 30%-80% the battery might be faulty
I have waited yet another battery cycle to collect more details, and discovered that the low battery behaviour does not trigger because as soon as the battery drops from 30% it goes directly to 0% and the critical battery sequence triggers in, saying it will shut down in 60 seconds.
So it all comes down to the battery percentage readings that might be wrong.
It does say 69% degradation but the Framework Control GUI says “charge to 100% to recalculate battery health”, I’ll update with the results later
In the info center:
14,50±0.2 V while above 30%
12.00± 0.2 V shortly after dropping below 30% (straight to 0%)
I also tried to record the 30 to 0% drop, but it instantly interrupts the screen recording. I guess it stops not system process
