Unrelated Support Ticket nonsense
I’ve tried to submit a support ticket twice. I’m not sure what happened, but it failed to submit both times. The first time it ate my painstakingly written message.
I suspect the form doesn’t like either having an empty value or 'n/a' string in the BIOS field (tried both), but since I’ve never gotten the laptop to POST I have no idea what the BIOS version is. It’s whatever it shipped with.
Maybe there’s a future where there’s an enhancement to the form that takes the user back to their submission to correct it rather that just eating it when there’s an unhandled error. ![]()
Setup
- Framework 13 Pro
- Intel Ultra 3 X7 358H
- Micron 32GB LPCAMM2 Module (from Framework)
- Samsung 990 EVO Plus 4TB
- No OS yet, haven’t gotten that far.
My issue
TL;DR Assembled the laptop and it fails to POST with the “memory incorrectly installed” error. Reseating LPCAMM2 module did not help.
Just documenting this really. I’m pretty sure I’ve identified the issue and know the solution. The question is just how I can most quickly and effectively get there.
I did a bit of sleuthing (mostly here on the forum) and found that these kinds of issues seem to be related to interposer physical damage. I checked the interposer and it looks like there’s 2 damaged pins. I took a bunch of macro shots of the interposer highlighting the damaged pins as well as the LPCAMM2 contacts, motherboard contacts, and back side of the interposer. The only damage I can see is the 2 pins on the front of the interposer. Everything else looks fine. I proactively attached photos of the other components to my failed support tickets, but I’m only attaching the 2 relevant photos of the interposer here in the forum.
Just hoping I can get a replacement interposer ASAP so I can start using my new laptop, whether that’s via warranty, at my cost, or if you can’t source one quickly - where I can potentially buy a replacement myself.
I’ll circle back and see if I can’t get the support ticket actually filed.
