Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
Hi,
The FW16 has 2x M.2 slots for SSD and 1x M.2 slot for wifi.
Does anyone know how much power these are permitted to draw. Values for sustained and peak needed.
This is more from the point of view of what the FW16 is designed to be able to supply, than the SSD datasheet values.
As a side thought, might it be the SSD that is causing FTR problems, or brownouts when the systems is mostly idle?
