Microphone Not Working on Framework 13 (2025) and Fedora--the solution
AMD Ryzen™ AI 300 Series Fedora 44
I’ve had a lot of trouble getting the built-in microphone working on this machine, and there are lots of community posts with the same issue. I have a solution. Do the following. Create and edit this file, blacklist-snd_soc_dmic.conf:
sudo nano /etc/modprobe.d/blacklist-snd_soc_dmic.conf
Add this to the file:
#Default to analogue mic
blacklist snd_soc_dmic
Then save and exit.
Then:
sudo dracut -f
sudo reboot now
After the reboot you may have to go into sound settings and turn up the input volume (mine was at zero).
