Hi all,
Does the Framework Desktop come with a microphone or can anyone recommend a good microphone compatible with Arch Linux?
Thank you
Thomas
Hi all,
Thank you
Thomas
The rear 3.5mm is a mic / headphone combo port.
You will get better sound quality with usb based audio devices. The analogue mic signal being close to all the mainboard noise is likely to add some noise to your mic signal if you use the jack at the back of the unit.
really?
