Missing partition on newly installed Fedora
Fedora 42
Which release version?
42
Which kernel are you using?
Not sure
Not sure - whatever was installed at shipping last week
AMD Ryzen™ AI 300 Series, latest batch
Hi,
I just got my Framework 13, and immidiatly followed this guide to install Fedora on my machine. All worked well, and I got started installing applications and such. During heavy usage, I suddenly got a crash, after which a partition was found missing (photo included). I did a fresh install. This time I tried to update the various software installed on the machine in the Software application in Fedora. The reboot done to install the updates triggered the same error message. As such, I suspect the issue is related to first reboot, not the first crash.
Now running Bazzite without issues. I’d prefer Ubuntu or Fedora though.
Any ideas on what to try here?
