ML-1220 clip replacement for RTC battery
Where can I get a replacement clip for my 11th gen
Looking at the Framework Github page for the Framework Laptop 12 mainboard, that part us from Cvliux (part number CVILU_CI4402M1HRC-NH). I looked around online and can’t find a vendor - you might be able to contact Framework support about procuring this item if you can’t find any for sale online.
That being said, you’ll also see on that Github page the following text:
The only case where an RTC battery is needed, is when the system is used in standalone mode (without a battery).
It sounds like you should be fine with using your FW12 without the RTC battery connected.
  • When the mainboard is installed in your laptop, the laptop’s main battery will perform in place of the RTC battery.
  • If you were to take your FW12 mainboard out of the laptop and put it into a custom case to use as a small personal computer (sans laptop battery), that RTC battery would be important.
It looks like you’ve got a FW 13 with an 11th gen Intel mainboard. This is the sub-forum for the Framework 12 laptop.
You might get more answers posting in the FW 13 section. Although, a quick search shows multiple threads talking about broken RTC battery holders, and nobody seems to have sourced one.
If you are comfortable soldering, you might reach out to support and see if you are still able to get one of the RTC battery eliminator boards. They are designed to clip into the holder, but you could probably use some small wires and solder it into the necessary circuits and then secure it with kapton tape or something like that.
Unfortunately this is not true for the Laptop 13 11th Gen, and this post has been miscategorized.
BAHHH dangit. Thanks!
It looks like the correct RTC battery connector for the FW13 Intel 11th through 13th gen boards use the LOTES AAA-BAT-046-K01 which IS available for purchase online. I haven’t bought anything from this vendor so use at your own risk, but some company names ‘LCSC Electronics’ sells them and has them in stock.
This part is listed here on Framework Github:
