Mouse freezing
Hi griffin here I have a framework 16 with
windows 11 amd ryzen AI 3000 series with NVIDIA® GeForce RTX™ 5070
And have been experinceing random mouse freezing issues has anyone else experinced this issue and found a solution to it thank you if you can provide any help
What kind of mouse do you have? Is it a wired one via USB?
A few questions that would narrow this down a lot: is it the built-in touchpad that freezes, an external mouse, or both? And if it’s an external mouse - wired, 2.4 GHz dongle, or Bluetooth?
Two things are worth doing regardless, because Framework publishes firmware and driver updates for exactly this machine:
  1. Install the current BIOS. For the Framework Laptop 16 with Ryzen AI 300, the latest stable release on Framework’s official BIOS & Drivers page is 4.01 (July 2026), and its changelog mentions an updated input module app - the input modules are the parts that include the touchpad, so if your freezing is on the built-in touchpad this is the first thing to try.
  2. Install the matching Windows Driver Bundle (v2.00, June 2026) from the same page, if you haven’t already.
If the freezing is with an external USB mouse, one more quick test: Windows has a power feature called USB selective suspend that can suspend idle USB ports to save power (it’s documented by Microsoft). You can turn it off as a test under Power Options > Change plan settings > Change advanced power settings > USB settings > USB selective suspend setting > Disabled and see whether the freezing stops.
I haven’t hit this exact issue on this machine myself, so treat these as the documented basics to rule out first rather than a proven fix - if you post which mouse and connection type it is, people here can likely get more specific.
i use a the trackpad and a mx master
the touchpad and the mx master i use with the included dongle it seems to freeze and thank for the addvice
Thanks, that detail helps a lot. If the built-in touchpad freezes as well as the external mouse, the mouse itself is ruled out - something upstream is stalling all input at once.
The next official step for exactly this machine, after the BIOS, is Framework’s own driver bundle. Framework’s release post for the Laptop 16 with Ryzen AI 300 lists Driver Bundle v2.00 (June 2026) as the current stable, and it updates the AMD chipset driver, the AMD graphics driver and the NVIDIA driver among other components. Chipset and graphics are the parts most likely to stall input system-wide, and the bundle is the driver set Framework tests and supports for this model - so it is worth installing even if Windows Update shows nothing missing.
Two observations that would narrow it further:
  1. When it freezes, does input come back on its own after a second or two, or does it stay dead until you do something (like switching apps or replugging the dongle)?
  2. Does it happen more under load (games, video calls), or also when the machine is idle?
And one cheap experiment for the MX Master specifically: a 2.4 GHz dongle right next to other USB-C devices in a metal chassis can add its own hiccups on top of everything else. Running the mouse over Bluetooth for a day splits “system-wide stall” from “dongle trouble” cleanly.
Hi @Rei_Kurosawa, welcome to the forum!
It looks like you’re using generative AI to generate your help. :robot: I’m not a mod here, so am just speaking for myself. Just a customer and occasional commenter.
I’d suggest that (a) any robot help is declared, so readers can make their own judgements as to how much to trust it, and (b) if you can contextualise AI help and offer your own human thoughts and experiences, that adds much more value. Any question author can of course can ask their question in a AI tool themselves.
I also contacted framework support they sugested i reset the bios I have done that and will update the form if it fixes the issue I would not want other people to have this issue
Fair point, thanks for the welcome.
Partly written with AI assistance.
Sometimes these issues can occur if something is going on with the SSD. Download the vendors software to fully test the drive might turn up an issue. Do not always depend on S.M.A.R.T to identify issues with storage drive.
Another thing to try is making an Ubuntu or Fedora USB and booting from a live instance. If the issue goes away then it is definitely a software/OS issue causing the brief stuttering. A different test may be performed by booting into Safe Mode for Windows and seeing if the same issues occur. That may or may not make a difference, if it does though then it is definitely something in how Windows is configured and the drivers/services that are running.
Just another couple of things to try to help isolate the issue that is happening.
Same here. The internal trackpad freezes for about 30 secs - no movements, no taps working. It’s not a UI freeze - I can still navigate between WM’s windows, open new ones etc. It happens quite rarely though.
I’m on Intel Ultra 5 125H, btw, so it’s not necessarily an AMD specific issue
update after i reset the bios the issue has not seemed to happened this what support recomened I do “try to Reset BIOS settings: Go to the BIOS by pressing F2 while turning the laptop on, press F9 to set up defaults, and F10 to save and exit, and check for any changes.”
I have a updated it seems to be the whole system freezing
Would you be more specific here? It is not clear what you have updated.
Is this immediate upon switch-on i.e. your system won’t boot into your OS? Or is it intermittent, and happens when you are doing something in particular? Can you get into the BIOS and use it? The BIOS interface is itself a computer program that uses the CPU, so if that never freezes, then the cause may be something else (the GPU, the OS, etc).
ahh i mean an update on information / the problem it just happens semi randomly when using the using the os both times i was using chrome I will have to looking at event viewer for more information I hope that provides more clarity
