MT7922 mediatek wifi card wifi/bluetooth issue
I am using framework 13 amd 7840u with ubuntu 25.04 with all the latest kernel and driver versions. When i want to use wifi and bluetooth together it won’t work like when ever i connect to my bluetooth earphone the wifi stops working but as soon as i turn off my bluetooth the wifi works fine any solutions?
Issue is fixed the wifi and bluetooth both were fighing for 2.4GHZ when i switched wifi for 5GHz both works in tandem without switching wifi off but if still anyone knows any different solution please reply
Update regarding usage when both are on the wifi works but it’s highly unstable
Make sure your wifi card is setting its regulatory domain correctly. Here is the Arch Wiki page on it.
thanks I’ll look into it
