No Charging Indicator
I’m on a framework 13 AMD AI 300, running endeavor OS. The problem I have is when I went to turn my laptop on it wasn’t booting and there was no charging indicator.
additionally the right side of the laptop was warm, but after I unplugged the charger it cooled down. I’ve tried disconnecting and reconnecting the battery but I still don’t see any charging indicators and can’t boot.
It might be worth leaving the charging cable in for a while, in case the battery is at zero, and it needs a few moments to achieve any charge at all. Continue to monitor the temperature though, in case there is a fault.
Something I’m noticing is that when left unplugged a slight warmth builds on the right side of the laptop. It isn’t burning, but when I remove that battery that warmth seems to stop.
Another thing to check - I only have a new 13 Pro, and I don’t know what the power switch looks like on the 13, apologies. Does your power switch have an integrated power lamp?
My computer once refused to wake from sleep, and I initially thought it was faulty. The power lamp was on, but I could do nothing to get the integrated display or an external monitor to work. I had to press-and-hold for ten seconds to properly power-off the machine, and then I could reboot as normal.
Can you boot with the battery alone? If so the ISL9241 charge controller is likely broken. Remove the mainboard, the charge controller is on the back side
I’ve let the battery drain overnight and now I notice that when I plug my laptop in there is a noticeable humming sound. I noticed that noise also happened when I plugged in the framework with the battery disconnected.
I’ve tried booting it uncharged and it didn’t work. Is that what booting with battery alone means or does that mean something else?
Typically there are 3 power paths in a laptop, adapter → system, adapter → battery and battery → system. Framework doesn’t enable bypass changing on the AMD AI 300 Series so adapter → system is absent. The computer is unable to change the battery means the ISL9241 or its power FET is likely broken so adapter → battery path is now damaged, you can “let it drain overnight” means the battery → system is okay.
RMA if within warranty and go to a repair shop to fix the ISL9241 charging circuit if out of warranty. The battery is okay, only discharged, so if the charger is fixed it should then charge normally
