Noisy PSU fan
Hey, just wanted to thank you and @Stebalien for the idea. I ordered a bunch of these 40 mm x 40 mm heatsinks as well and installed three of them just like in your image a couple of hours ago. Since then I haven’t heard the power supply fan once when usually it would turn on every 10-15 minutes or so. It’s also my only mod so I can rule out that anything else was responsible. It’s almost too quiet now. :smiley: Even if it should eventually turn on when the system and ambient temps get hotter under load or in the summer, this is a definite improvement!
EDIT: After approximately 5 hours of light work and watching some videos, the PSU fan did make itself noticeable again. Still, seems quite a bit better than before, especially for shorter sessions.
I’ve tried adding an 80x40mm heatsink to the top of mine! Feels like it’s helped a bit, but I still hear it coming on every few hours, for long enough at a time to be annoying
Tried the fin mod today. Added 3 x 40x40mm fins. I also have all the other mods and it seems as if - although PSU definitely feels colder to the touch now - it increased internal case temperature by 3 - 5 °C.
I did mod my PSU with a Noctua fan. Could very well be that the temperature increase is because I had tape covering a gap in the PSU case because my Noctua replacement is a bit thinner and that tape might not cover the gap anymore. Was lazy when applying fins and did not disassemble everything but applied them just like that. Since the Noctua PSU fan mod had a longer cable I taped it to the top of the PSU where the fins had to go. When I removed the tape I might have also detached the gap tape.
Will likely remove them again. Here a list of all my mods so far:
Edit: after a full day I removed the fins again. Internal temperatures are ~3 - 5°C lower that way.
Wow thanks, just placed my order. Got some 80x40mm and 100x60mm, will see which one fits and looks better.
Also got a bigger heatsink to make this project to fit it under the PSU Desktop PSU noise fix
These heatsinks, together with the front 80mm front fan and my 2 USB fans, I think I achieved peak FW Desktop cooling lol Extra cooling on FW Desktop
It really doesn’t seem like Framework is going to ever do anything about this. It’s been almost a whole year now. If they were working on it at all it would have been addressed. Pretty disappointing considering they specifically hyped all the work they did to make the PSU quiet and it clearly doesn’t perform as well as they described.
the noisy psu was driving me nuts (fw desktop, ryzen ai max+ 395, noctua fan), until i flipped the cpu fan to “always on” in the bios. here’s what I saw before the change:
  • ~11‑12 w power draw
  • ~48‑54 c temp, right near the high end
  • apu fan would spin at ~54‑55 c on a low cycle and stop when the temp dropped to ~47 c
  • psu fan cycled on/off like it was on a set schedule
after switching to “always on”, my numbers changed dramatically:
• ~10 w power draw (not sure why, but it happened)
• ~32 c temp, sometimes as low as ~29 c
• apu fan ran steady at ~695‑705 rpm
• psu fan was silent
I also changed the apu fan sensor from “cpu average” to “cpu” to cut lag on sharp temp spikes. this is useful for ai workloads, though unrelated to the psu noise problem.
With these tweaks, I’m a happy camper as the desktop is dead silent (you can’t hear the nactua fan on low cycle) and runs significantly cooler. give this “mod” a shot before you go for the more invasive, hardware-based mods.
update 1: the psu fan does come on when i’m pushing the system, of course, and it’s as whiny and noisy as ever. but, with the tweak described above, the system stays absolutely silent when idle. i’m hoping framework will release a firmware fix or a new revision of the psu unit that addresses the unpleasant psu fan noise issue.
Similar experience here - fan always on, but low speed - and there is seldom any noise at all. I’m not pushing any heavy workloads, however.
@Eagle any news on this issue in time for the upcoming anniversary?
If anyone wants to see the size difference between these, here they are. The 100x60 would fit fine, but I went with the 80x40 as I also have an LED strip (priorities lol).
Shout out to @James_Milroy for the heads up, and folks at Overtek for shipping the alternative PSU with Noctua fan. It solved the problem for me. In case you missed it: Custom Enhance ENP-7660B PSU fitted in my desktop
Hey folks, giving a quick update on my end because I’ve honestly hit a brick wall with Support, and I think everyone here needs to know what Framework’s official stance is behind closed doors.
After months of back-and-forth on my Framework Desktop, here is what my support saga looks like:
  • First, they had me jumping through hoops trying fixes like doing a mainboard reset.
  • They also asked me to run live USB Linux distros just to rule out the OS.
  • Then they made me spend hours tearing down my daily driver to test and film both PSUs completely outside of the chassis.
  • They finally sent me a replacement PSU, which somehow made the PSU fan noise much louder than the original.
  • Next, they suggested doing a full mainboard swap. I pushed back on this because I would ALSO need to wipe my SSD and the computer is my daily driver for my business. I can’t afford the downtime.
  • A frontline rep then admitted to me that mainboard swaps haven’t even solved this issue for anyone anyway. They have no engineered fix.
I was fed up, so I escalated the ticket all the way to Sandy, their Head of Customer Experience. I didn’t ask for a miracle. All I asked for was a commitment to monthly updates on their engineering progress, and a promise to authorize an alternative fix in 6 months if they still couldn’t produce a quiet PSU batch.
Sandy flat-out refused both requests.
I was officially told my only two options are to pack up the machine and return it for a full refund, or leave the ticket open indefinitely and wait for an update that might never come.
Let’s be real here. I’m 6 to 7 months into my 1-year US warranty. I have absolutely no doubt that Framework is just trying to run out the clock on this issue until our warranties expire so they can wash their hands of it. They have no actual fix, and apparently zero intention of keeping us updated.
Honestly, I’m just incredibly disappointed. I bought into Framework specifically because of their reputation for engineering prowess, modular innovation, and top-tier customer support. To see them completely stonewall a customer and offer an ultimatum instead of an engineering solution is a massive letdown.
Is anyone else getting this exact same runaround from support?
I have a lot of sympathy with a poor support experience with this or that provider/supplier. However, a good (and scaling) support department generally has to have a process, and processes do sometimes miss edge cases. I feel your pain, but sometimes human communication is such that it looks like one side is being devious when, if there were any such thing as a neutral arbiter, perhaps they’re just doing what they can in a complex process.
It’s always hard to know how to strike the right balance. Maybe they could have a “break glass” support option - once they’ve spent $200 on labour investigating your case, they might as well give you a non-standard fan, even if it costs them another $100 to do so.
However, the full refund isn’t a bad option for your business continuity - could you buy a non-Framework machine, get a refund from Framework, but retain the drive? If you’d gone with Dell or HP I suspect this would not have been on the table.
Thank you for sharing your experience. It is a shame users have to build suitable drop-in replacements because Framework can’t be arsed to fix this.
@Eagle you stated the team was looking into this. You ignored my latest ping on this issue - still interested in an update. Is @zzzz8 correct in their assessment that Framework decided to just ignore this issue? Would be nice to have some clarity.
Thanks wolfie.
It got to the point where I was thinking Framework was “testing” me to see if they would break me to get me to drop the issue and/or then blame me for not following their suggestions. I followed all their suggestions and it amounted to hours of work on my part. My estimate is around 12+ hours.
What really disturbed me were two things. They sent me a PSU whose fan was noticeably worse when it came to the noise. It made me think that they sent me an old PSU fan just to test and make sure I wasn’t “lying” about the fan noise. Second, they proposed sending me a mainboard replacement knowing full well that it was unlikely to work (they admitted later that a mainboard replacement has NOT worked for anyone else in the past to fix the noise issue). Moreover, they specified that it was best for me to reinstall Ubuntu on my SSD once I got the new mainboard. To me, this shows a lack of respect for my time.
I’m sure my cynicism shows - and perhaps I’m a bit too cynical now, but my experience supports my cynicism.
I feel your pain. Went through multiple support & replacement processes for multiple devices myself. Even though it can be a pain sometimes I respect their need for multiple images and other proof. The sad part is that 1st level support is working off scripts that they have to follow, which can be quite off-putting, especially for very technical customers. Not talking about myself, but there are stories from people who clearly know what they are doing and bringing receipts, only to get canned replies and their findings mostly being ignored.
I appreciate Framework going the extra mile in fixing things and making affected users whole. Some issues took long but as far as I know they usually deliver in the end.
That said - I find their communication in those situations extremely lacking. See cracking FW12 chassis where it’s basically a single person dealing with us here in the forums.
The PSU fan issue being even worse. In the sense that they put out false advertisment for their product (see their blog post about complete silence, a fan that was developed / adjusted specifically for the PSU with their own profiles / curves, which just is not true). Again no communication at all and now them seemingly telling us to suck it up (which would be an alarming first).
So any official update would be really appreciated.
Maybe a temporary (and not complete) workaround for the future buyers would be to give the option to get the DIY edition without the PSU.
It doesn’t really solve the problem, especially for people who already got it, but it could at least give the opportunity to new buyers to spend the money saved on something like what @James_Milroy did. And maybe it could also lower the weight put onto the support (which could then address each issue more thoroughly). :man_shrugging:
When we’re talking about more DIY approaches, I think it’s important to call notice to the mainboard-only purchase option. I just finished a mainboard build with a standard Corsair SFX PSU, and it’s performed wonderfully (and the PSU is silent). Not quite as small of a case, but still small form factor. This by no means excuses the problems in this thread, but I think it’s important for new buyers to know it’s a good option.
Oh hey dude. You pinged me before? Sorry. Im not sure what happened. You know I would never and have never ignored you purposely. Its the weekend, so let me check and respond back as quickly as I can.
No worries. It was a regular post in this thread and easy to miss. It’s the community forum and not the support hotline after all.
Just curious about the state of fixing the PSU noise - especially seeing @zzzz8 quote from their support experience, which seems to have been escalated quite high internally. Wondering if PSU is a closed issue or if we can expect any update.
Personally if I am 100% honest I don’t even expect a free replacement, since I made my own modifications already. I would order a revised v2 though if it became available since I would very much prefer a PSU that I have not tinkered with and that is as advertised.
In my case the fan noise is covered by whine coil. I believe whine coil is coming from the PSU.
In heavy load, well… kind of… Mistfall hunter 1080 P at high settings,locked @60 FPS is the worst.
