Normal temps & fan usage?
Hey all,
I’ve increasingly been getting what I suspect is excessive fan usage/heat in my Framework 12, so I wanted to check in with the community and see if this is a known issue/just kind of what to expect with the form factor?
I first noticed the issue when CPU usage would spike up and fans would kick in audibly when using Firefox with a poorly-optimised website. I changed the power settings to ‘Balanced’ and that solved it for a while, but then the issue started recurring. I installed fw-fanctrl and set it to the ‘lazy’ setting, hoping it was just an overly aggressive fan curve. However, fw-fanctrl is consistently reporting temps of 74C+ and even the ‘lazy’ fancurve is constantly at (a very audible) 50% fan speed trying to cool the laptop.
I’m not doing anything crazy - web browsing, Discord, and a word processor are usually the only things running, and I’ve made an effort to not have more than 15 tabs open. CPU usage is typically between 15-20% and RAM usage is usually ~15GB in the system monitor, so I don’t think anything is consistently taxing the system in a way that should lead to excessive temps. The laptop stays in one place 99% of the time and doesn’t do the kind of travelling where it could get knocked around/damaged.
Is this kind of temperature/fan usage just normal for the 13th gen i5 FW12, or does it indicate something is wrong? Anyone else have any experience with resolving this?
System information:
Operating System: Fedora Linux 44
KDE Plasma Version: 6.7.5
KDE Frameworks Version: 6.30.0
Qt Version: 6.11.2
Kernel Version: 7.2.4-200.fc44.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 12 × 13th Gen Intel® Core™ i5-1334U
Memory: 64 GiB of RAM (62.5 GiB usable)
Graphics Processor: Intel® Graphics
Manufacturer: Framework
Product Name: Laptop 12 (13th Gen Intel Core)
System Version: A5
There’s no intake at the bottom of the chassis. You can probably DIY one No cooling holes - sustained performance hits?
I have the first i3 version and i can confirm that it’s easy to see fan spiking up.
I’ve solved it by using the Power Saving mode and changing only when it requires it (1% of the time tbf). This isn’t a definitive solution tho, obviously if you use all your cpu in PS mode, fan’s gonna start anyway
In my experience this CPU (i5-1334U) likes to overly increase its power usage with small loads like that. I guess that with your 15% cpu usage it’s at quite high clocks and takes at least 8W from the battery which makes the fan work pretty much continuously.
My 1st gen i5 also tends to be very fan heavy. I think it may be a firefox thing? I’m using the laptop and external monitor but really, it’s just running a youtube in one screen and one tab on the other screen. I don’t do tabs and what not, I can’t figure that out in my brain as a way to work!
I think it’s just the nature of the machine. Performance seems to be ok either way.
Thanks everyone. I set the power profile in Fedora to Power Save instead of Balanced and fw-fanctrl on lazy now keeps the laptop running reporting ~65C with fans at 24%, which is inaudible. It doesn’t seem to have a noticeable performance impact on my daily usage so I suppose the solution works, although it is kind of annoying that I now have to manually manage this setting if I do want to use the laptop for a higher-intensity task.
It is what it is, I guess! I hear Gen 2 CPU options are more efficient, so one day when I decide to upgrade I imagine the problem won’t exist anymore :slight_smile:
