Framework Laptop 16 - AMD Ryzen 9 7940HS with AMD Radeon RX 7700S
Linux Mint 22.3 - Cinnamon
OBS 32.2.0 from official PPA
I’m trying to record video of Minecraft playthrough but having issue trying to isolate the sound. If I keep global desktop sound, it will capture it but when trying to capture just Minecraft, I get no sound. When researching the issue, I came across a plugin "Application Audio Capture (PipeWire) and installed it using and set single application capture mode, match by execution name and application java.
Any thoughts?
Hmm, I wonder if this has something to do with how Minecraft runs through Java. Since the desktop audio works, maybe OBS just isn’t recognizing the game the way you’d expect. Not entirely sure though.
Two things worth checking. First the PipeWire version (pipewire --version): in the plugin’s GitHub issue tracker there is a report (#96) with nearly your exact setup - Linux Mint, Minecraft/java visible in Application Audio Capture but no sound - and the author traced it to an outdated PipeWire; the README recommends 0.3.62 or newer plus WirePlumber. Second, while Minecraft is actually playing audio, check in pavucontrol whether it appears as a playback stream at all. If it doesn’t show there, it is likely outputting via plain ALSA instead of the pulse compatibility layer; per the plugin README, apps like that need pipewire-alsa installed. The Java/ALSA part is my hypothesis, but the version check comes straight from the author’s answer in that issue.
Hi @Rei_Kurosawa. On another thread you very kindly agreed to note when you’re copy+pasting from AI. Please continue to do that if you can.
It’s worth noting that adding some of your own human context, and typing those words yourself, is important for communities. I will flag to moderators any accounts that I think are posting automatically.
Where are you based? What FW kit do you have? I’m a proud owner of a 13 Pro, in the UK. I’ve been running it for around six weeks now - very solid bit of kit.
pipewire --version
pipewire
Compiled with libpipewire 1.0.5
Linked with libpipewire 1.0.5
wireplumber --version
wireplumber
Compiled with libwireplumber 0.4.17
Linked with libwireplumber 0.4.17
Seems I am using a version higher then the recommended one.
