Odd ~1cm border around display
Ubuntu
Which release version? 25.04
Which kernel are you using? 6.14.0-36-generic
Which Framework Laptop 13 model are you using? (AMD Ryzen™ AI 300 Series, AMD Ryzen™ 7040 Series, Intel® Core™ Ultra Series 1, 13th Gen Intel® Core™ , 12th Gen Intel® Core™, 11th Gen Intel® Core™) AMD Ryzen™ AI 300 Series (HX 370)
I have come across a display issue that I cannot seem to find any information on. There seems to be a weird ~1cm margin around the display. I am not sure if this is intentional or if it is something I did (from various images online it does not seem like the margin should exist).
Thanks in advance.
