Option for no touchpad?
A touchpad, especially one with no physical button is just unusable for a lot of people including me. As long as there is no option for a touchpoint (like a thinkpad) it means an external mouse is required.
I usually just disable the touchpad in the bios (when possible) or by software when it’s the only solution as it just gets in the way when typing.
I might also consider a flat panel to replace the touchpad if it’s available.
Linux and as far as I know any other Unix based operating system requires 3 buttons. How do you even make it work with a touchpad with no physical button ??
Tap with 1 finger = left button
Tap with 2 fingers = right button
Tap with 3 fingers = middle button
https://wiki.archlinux.org/title/Libinput#Tappin_Button_re-mapping
Not sure what difference it would make to ergonomics. I love the customiability option, howveer I would love the ability to have 1 metal piece instead of the 2. However it possible to go one step further and have 1 metal piece for the whole bottom half, that would be amazing. Extra cusomisability can’t be bad?
image source: The Verge article https://www.theverge.com/2023/3/23/23652967/framework-laptop-16-modular-upgradable-graphics
Touchpad is in line with the spacebar. Helps with keeping the correct posture.
Ah yes the customisability is ergonomic. I thought you meant it needing to be as it is was ergonomic for some reason
Hence the spacers to keep the alignment correct.
I don’t think we’re talking about the same thing
I would definitely prefer a laptop without a trackpad, but only if the area where the trackpad would normally be doesn’t exist on the laptop. In other words, I would like a laptop where the entire area facing up from my lap/desk is covered by a keyboard. Personally, I don’t want a trackpoint either. Just having a touch-screen would meet my occasional needs for a pointer, although I would love to use eye tracking if it supported Linux and worked well enough. The obvious problem with all this is that it would be hard to fit a powerful computer with reasonable battery life into this smaller shell. I would settle for a not powerful laptop with good battery life, but most people wouldn’t. Another problem is that a smaller lap-top area would necessitate either (1) a shorter visual display, which would make for an unusual aspect ratio, or (2) some complicated system to expand the display during use (e.g. telescoping, folding, or rolling). Hopefully the market will figure something out some day.
I have some practical complaints about most trackpads but my preference is mostly based on aesthetics and ergonomics. As people have said, trackpads can be disabled (on any operating system or distro). I have a function key mapped to toggle my trackpad so I can easily switch it on and off.
