Order Multiple Parts
I try to order a Framework Laptop 13 Mainboard AMD Ryzen™ AI 7 350 and the Wi-Fi-Module AMD RZ717 Wi-Fi 7. When I try to order I get the error
So, I ordered the mainboard first. But when I try to order the Wi-Fi-Module I get this Error
Any suggestion? Thanks Markus
@Markus_Zimmermann that means that the Wi-Fi module is out of stock at your local warehouse so it can only ship from the TW warehouse with new laptop orders right now. Where are you located? Will you send your order number over via modmail / DM? I’ll take a look and see for sure what’s going on.
An alternative would be, since that’s just a standard Wifi module, and nothing Framework specific, to get it on Amazon or eBay or wherever.
Likely cheaper, too.
was also looking for alternative sources but found only one listing in Germany and it´s a bit more expensive. I will monitor the FW Shop. Thanks
MB is changed, I simply use the Intel Wi-Fi Card for now and it works fine.
Thanks everyone
