Palm rejection not working
Sorry in advance if I am posting this in the wrong place. The community support category seems to push linux issues to this subcategory, and the keyboard-touchpad tag is only for the community support category, so I’m not sure where it should start.
Ubuntu
Which release version?
24.04.3 LTS
Which kernel are you using?
6.17.0-20-generic
26.96.0
Framework Laptop 13 AMD Ryzen AI 300 Series
AMD Ryzen AI 7 350 w/ Radeon 860M
Issue:
I’m having real problems with palm detection. After doing some initial troubleshooting, it looks like the issue may be that the touchpad is not providing the information needed to trigger it?
The PIXA3854 driver does not appear to expose contact size or pressure data to the kernel — ABS_MT_TOUCH_MAJOR is absent from the device’s axis list, as shown by evtest.
libinput list-devices confirms no palm detection capability:
Capabilities: pointer gesture
libinput measure touch-size /dev/input/event7 confirms:
This device does not have the capabilities for size-based touch detection.
Details: Device does not have ABS_MT_TOUCH_MAJOR
As a result, none of the following help:
  • AttrPalmSizeThreshold / AttrThumbSizeThreshold in local-overrides.quirks
  • AttrPalmPressureThreshold / AttrThumbPressureThreshold
  • AttrSizeHint
Disable-w-typing is enabled and helps during typing, but does not catch thumb contact during pauses.
Is there anything else that I can do? Am I approaching this problem incorrectly? The fact that the forum is not awash in issues related to this suggests to me that it is a me thing. I just can’t figure out what that me thing might be.
thank you
Did you mean palm rejection? It’s been frustrating for me, on Fedora 43/GNOME.
The best bandaid fix I have found so far is auto-disabling trackpad input any time it detects an external mouse, and using that instead for mouse input. This command should work on Ubuntu as well:
gsettings set org.gnome.desktop.peripherals.touchpad send-events disabled-on-external-mouse
To undo the setting: gsettings set org.gnome.desktop.peripherals.touchpad send-events enabled
Yes. Thank you for this, and also ugh that it is the best solution out there. I don’t understand how framework could decide to ship a trackpad that just doesn’t support this feature on linux.
Palm rejection has been an issue with running Linux on laptops for ages, well before Framework existed, so I wouldn’t necessarily put blame on them. Palm rejection on a Framework works just fine on Windows. Driver support on Linux for touchpads has historically been lackluster.
So the best solution is don’t use it.
That is dissapointing. It may be possible there is no decent palm detection support in Linux, but I tend not to believe that.
For me this is very dissapointing. I hope the devs will help us come up with something better, other then: then don’t use our product.
Tested with AI what may have been possible in Libinput:
sudo libinput measure touchpad-pressure
Using PIXA3854:00 093A:0274 Touchpad: /dev/input/event4
This device does not have the capabilities for pressure-based touch detection.
Details: Device does not have ABS_PRESSURE or ABS_MT_PRESSURE
sudo libinput measure touch-size
Tested in Elementary, but also experienced this in Fedora, all using Libinput in Wayland.
