I realize voting is over, and AMD^2 is already the only reality, but I want to give my 2cents:
I would like Intel CPU + Nvidia GPU.
1. I choose the Intel CPU + Chipset only for 1 reason: ThunderBolt.
It is simply the best Laptop-to-desktop dual usage technology I’ve ever experienced. I had returned or given away dozens of USB hubs, docks and expensive cables and adaptors) since they were all lacking stability, speed and range of options.
I was constantly getting disconnects when copying large files from external HDs. I was getting only 1 external monitor, and sometimes it was flashing for no good reason. Use 2 or 3 USB devices simultaneously, you were in murky waters. Frustration every time.
But most importantly, I was stuck with whatever crappy GPU was inside the laptop, usually outdated specs for most apps & games.
Then I discovered ThunderBolt 3, and I was blown away! I invested in the best at the time Docking station, the legendary CalDigit TS3 Plus, and I got my self an external eGPU case (the Razor X Core) with an Nvidia GPU. And things just worked great!
Multiple monitors, in high res. No disconnects of USB copying, no monitor flashings, no laggings and gaming like a Desktop, with a real Desktop GPU! And charging too, seamlessly.
And all that, via a single small and easy to connect and disconnect cable! For me, buying a Laptop without ThunderBolt is no longer an option! I’m hooked. Unfortunately, AMD doesn’t support ThunderBolt. They dont want to pay royalties to their competitor I guess.
But USB 4, is again a half-disappointment. Questionable supported features & speed depending on the whims of the chip manufacturers, non-certified equipment and cables, almost certain instability at high loads, limited expandability and non-existent support. And single monitor, did I mention that?
I want to be able to hook an RTX 3090 (500$ second hand these days) with 24GB VRam onto my external eGPU and know I can squeeze 90% of its power and throw 4 monitors at it. Can you do this with USB 4, with all USB4 implementations out there? I don’t know, I’m sceptical. Can you support the full range of great TB3/TB4 Docks out there? You most certainly can’t.
So I don’t care at all if battery on AMD CPUs lasts twice as much (which I doubt). I don’t care if it is 20% or even 50% faster for the same bucks (again, I doubt it). I only care about connectivity, ease of use and expandability. And sadly, only ThunderBolt guarantees that.
2. Nvidia:
As it was mentioned before: CUDA for AI apps, imaging apps and better GPU options overall. But for the initial launch, if I can have an external eGPU via ThunderBolt 4 I wont even need the expansion AMD GPU, so I don’t really care that much.
