AMD Ryzen AI 300
I’m having trouble with hibernation behavior and I’m not sure where the problem is or how to troubleshoot it. In particular, my laptop won’t start the display back up but will return to full operating power and when the lid is shut it usually stays at a high power state, heats up, kicks fans on, and drains the battery. It is like it is incorrectly handling sleep, hibernation, and power states in every observable way.
On AMD the culprit usually is the MT7922e driver.
On my Framework 16 / Ubuntu Resolute, removing the module prior to entering hibernate,
and reinserting at recovery from hibernate, seems to have solved the issue.
There are likely several posts on this forum and elsewhere on the internet that will explain
how to get that hooked up for your distro.
