Portable Power supply using RISC-V motherboard and Framework Battery
I was brainstorming on how to turn the framework battery into a power bank and found a few posts on here. It seems like the real bottleneck is properly communicating with battery so I was wondering if you could just dedicate the risc-v motherboard.
I’m wondering if anyone has more knowledge on the motherboard and if it could supply higher-voltage USB-C PD output from the battery. I think you would want to do it with the processor off, or you could do something cool like attach a screen for monitoring.
Do you mean a standalone FW battery, or using the FW battery as a PD source while it is in situ in a laptop?
