Power button light
+1 requesting ability to turn off (or RADICALLY dim) the LED or turn it to a less distracting color.
You can set the brightness of the power LED in the UEFI settings, but there are only three settings (bright, medium, dim) and the color remains white.
You can use the ectool to set it to blue, which is unsupported, and results in the light being off.
Since the EC source was recently released, I’ve opened a request there: https://github.com/FrameworkComputer/EmbeddedController/issues/11
Or even cleaner:
sudo ectool led power off
On another topic, I tried to get a finer control over led brightness by using
sudo ectool led power white=<value between 1 and 100>
But it doesn’t do anything :frowning:
Anyone know how to force the power button light ON? I just replaced my input cover after my original power light was only half lit, and now the light won’t turn on at all :frowning:
Changing the brightness level in the bios does nothing, and I’ve checked the cable three times.
…this doesn’t sound right. Connection or hardware issue I’m guessing.
Indeed. I’ve identified the cause as being the connector between the touchpad and board. I’ve already contacted support for instructions.
Both. I received a new input cover, which the power light does not turn on at all. And I’ve also disassembled/reassembled the connectors on my original one.
The power button light is a square “ring” around the fingerprint sensor, and the top right corner on my original power button light is not lit (as if a single LED is not working).
Hi I would like to boost this idea! This blue light is driving me mildly berserk. I might just put gaffa tape over it but that doesn’t seem like a good solution overall. Pls fix this one guys! Fanx, Claire
Apologies if necro’ing this thread is frowned upon, but I can find no better place to raise my concern:
I travel a bit too much sometimes for work, and the putting the FW13 to sleep often leaves the power button light pulsating for some time at night. I’d prefer a setting that would let me have the power button light turn off in sleep mode - or is this a problem with updates or w/e.
As is, my workaround is to simply shut the laptop, but occasionally I forget and while trying to sleep I end up having to get back up to close the cover. This wakes the laptop …ugh.
Or am I missing a workaround?
Win 11
Can confirm hibernate saves alot of battery compared to sleep
oh dope! I just assumed it was a super super low power state
Well off is technically a low power state XD
Hibernate saves the current memory state to disk and then shuts down. When you start again it’ll load said state and it’s back where you were.
Its been a few years… I was curious so i decided to find every exposed firmware LED and behold you can change the brightness now. I made chatgpt write me a little python script that uses fake pwm to dim the light (ai is bad) and it works great.
