Power button not working FW 13 Pro
. hey guys, I just unboxed and got my framework 13 pro ((intel put together) and everything works aside from the power button. I have to power it on using the one on the motherboard. What would you do?
Yes, I’ve tried unplugging and plugging in the tarp cover a few times
I’d contact Support.
Contact support and let them know like the other post said.
Try disconnecting and reconnecting the power button module on the main board. Presumably all the components are tested before shipment so it did work before it left the factory. Maybe it came loose in shipment.
Work with support though. At least there is a secondary means of powering it on other than dangerously using a paperclip!
Issue has been fixed wasn’t sure how to mark on the forum…
The Ribbon connector on the PCB side of the input connector had come loose at some point in time and i hadn’t noticed.
