I’ve been having a hard situation with Framework Support and two malfunctioning adapters.
I bought a 60W adapter from Framework that stopped charging my computer correctly. Because it was within a year, it was covered by the warranty and Framework sent me a new 60W charger in May 2025. I would expect it to work at least a year because the adapter is supposed to work for one year minimum.
However, the second charger broke about 7-8 months later (broke = stopped charging, not breaking apart physically in a visible way). Framework Support confirmed it’s malfunctioning after I sent various pictures and videos.
Framework Support says that replacement products only have a 90-day warranty. I asked for flexibility because the spirit of selling products is that they should last, and the second charger should have lasted at least a year (at minimum! but it should really last for more) even if there is a loophole limiting the warranty to 90 days. But I was told multiple times that the second broken adapter is not eligible for a refund.
I wish that the people at Framework would build some good will by acknowledging that having an adapter AND the replacement adapter both break after less than a year isn’t great.
I also wish Framework would find a way in this case to issue a refund, even a credit (which would encourage continued shopping with Framework), or a replacement (although this isn’t ideal given the track record of the adapter). It would be an exception to the current policy but it would be a relatively small token to adress a problematic situation. Instead, I was recommended to buy the same adapter again.
(edited = clarifying that the adapter was not charging correctly, not that it was physically falling apart in a visible way)
