Problem with two 5k monitors
I used a setup with Windows 11 and three monitors (5k, 4k and 2.5k). This worked fine.
Now i wantend to change this to a setup with two 5k-Displays (connected via Displayport).
The second new monitor works a expected - but the first monitor falls back to a 4k resolution, as soon as i connect the second 5k-Display.
The native resolution for the first display is not shown in the Windows settings. Does the Framework Desktop not support two 5k Displays at the same time?
Are you daisy-chaining the two monitors? i.e. one lead from your laptop to the first monitor?
No, i connected both individually to sepate Displayport-Connectors. Both displays are fixed to 120Hz and 10 Bit colour depth - perhaps there is a problem with the bandwith of the GPU? i will try to reduce the refreh rate to 60Hz during the weekend.
The problem is solved: i had to unplug all displays, wait for a few seconds and reconnect them in a different order. Very strange…
Now i can work with two 5k Apple Studio Display XDRs while keeping the 120 Hz refresh rate :slight_smile:
Ah, I’ve not heard of that behaviour before. It might be worth plugging in one (or both) of the monitors via USBC → USB-C, in case that exhibits more reliable behaviour.
