Rag project for framework laptop repair
Hello Framework team and Framework enthusiasts!
I’m Yusuf, an undergraduate student of statistics, currently developing myself in
Data Science. I am currently taking a course on "Building a Q&A System
Using Large Language Models (RAG, Retrieval-Augmented Generation). As part of the
of the course requirements, we have to develop a project to get a
certificate.
Framework guides (repair/replace) are a great example of a “knowledge base” for building RAG systems. Can I use them for my project?
I’ve already checked out the Guides API, but I think I need an APP ID to use the API.
to use the API. If the answer to my first question is yes, can I get an APP ID
for the ETL process?
Some from framework team can answer (yes/no) my question I will appreciate. So I can look for another resource or start working on this knowledge base.
I also plan to deploy this project and share here and reddit community.
Cheers!
I’m not framework affiliated, but be sure that your model’s source code and responses are consistent with the guide license.
Hi @Be_Far Thank you for reminding me about the license.
I’m not actually developing any model. Rag is basically sharing “knowledge database” with large language models and using it asking question.
Most use case is FAQ answering.
But sharing code is also mandatory for course. And I will share too for who is interested.
I guess framework not intersed. I will look for another source.
This is primarily a user forum. While Framework staff does post here, they aren’t guaranteed to see every post, and this isn’t an “official” means of contacting support, or getting a guaranteed response to a question.
If you want to get an answer for a question, you can use their “contact us” link: frame.work/contact-us
