Regular system freeze. Need help investigating
For at least a month I’ve had frequent total freezes of my Framework 13 laptop and sometimes even 3 times in sequence after rebooting. It always requires a forceful shutdown.
At this point I’m getting worried that it might be a hardware failure. But I have no way of knowing.
Most of the time the crashes are random. Pretty much all scenarios of prolonged and short time use, high and low performance use and on an input or when just not doing anything.
But I’ve had it now multiple times that immediately after rebooting that the system freezes after logging in.
It wasn’t too long ago that I installed Fedora from scratch so everything is relatively fresh installed.
Any tips or pointers would be appreciated. Thanks!
Operating System: Fedora Linux 44
KDE Plasma Version: 6.7.4
KDE Frameworks Version: 6.29.0
Qt Version: 6.11.2
Kernel Version: 7.1.13-200.fc44.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 7840U w/ Radeon  780M Graphics
Memory: 32 GiB of RAM (30.6 GiB usable)
Graphics Processor: AMD Radeon 780M Graphics
Manufacturer: Framework
Product Name: Laptop 13 (AMD Ryzen 7040Series)
System Version: A7
My first thought - have a look at dmesg to see if you can see any interesting system logs in there.
Also, get some temperature-sensor software on the go - it could be an overheating problem.
For this, I’d put memtest86 on a boot drive, and run through the immersion tests on your RAM.
Definitely check the temps. Have pets? It would be worth taking the machine apart and cleaning the fans and vents. If the machine can not cool down fast enough it will send itself into a panic and shutdown/lock up. Just some things to try.
Depending on how heavily the machine has been used it could be the processor and heatsink might need to be repasted if it has been a few years and had lots of heavy processor use.
To rule out the SSD, try booting from a LIVE USB and see if the same thing happens. Have seen things like this happen in the past and it was a faulty SSD that had not reported being bad yet.
I got another freeze and was able to investigate it a bit more.
I used journalctl -b -1 and looked for the timecode where it froze and I found this.
So it seems my AMD driver crashed. During the freeze I was still able to get sound and could change the brightness of the screen. And I got some more processes happening after the AMD driver crash so everything else seemed to still be running.
Sep 11 17:08:58 fedora kernel: RIP: 0010:mod_power_set_psr_event+0x4bc/0x4f0 [amdgpu]
Sep 11 17:08:58 fedora kernel: Code: 2d fd ff ff 48 89 ef 4c 89 0c 24 e8 2e c9 fe ff 4c 8b 0c 24 48 89 c7 8b 44 24 20 e9 11 fd ff ff c6 44 24 08 01 e9 84 fd ff ff <0f> 0b e9 7>
Sep 11 17:08:58 fedora kernel: RSP: 0018:ffffd23a00bd7d00 EFLAGS: 00010246
Sep 11 17:08:58 fedora kernel: RAX: 00000015c25dce20 RBX: 0000000000000001 RCX: 0000000000000007
Sep 11 17:08:58 fedora kernel: RDX: 000000000009a7c7 RSI: 000000000009a340 RDI: 00000015c2542659
Sep 11 17:08:58 fedora kernel: RBP: 00000000000003e9 R08: 0000000000000021 R09: 00000000000036aa
Sep 11 17:08:58 fedora kernel: R10: ffff8e9a63c00000 R11: ffff8e9a56f40000 R12: ffff8e9a43975600
Sep 11 17:08:58 fedora kernel: R13: ffff8e9a56f40000 R14: 0000000000000001 R15: 0000000000000000
Sep 11 17:08:58 fedora kernel: FS:  0000000000000000(0000) GS:ffff8ea2037ea000(0000) knlGS:0000000000000000
Sep 11 17:08:58 fedora kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Sep 11 17:08:58 fedora kernel: CR2: 0000562aa2ef5a84 CR3: 000000054ac2c000 CR4: 0000000000f50ef0
Sep 11 17:08:58 fedora kernel: PKRU: 55555554
Sep 11 17:08:58 fedora kernel: Call Trace:
Sep 11 17:08:58 fedora kernel:  <TASK>
Sep 11 17:08:58 fedora kernel:  amdgpu_dm_psr_set_event+0xce/0xe0 [amdgpu]
Sep 11 17:08:58 fedora systemd[1514]: Starting plasma-restoresession.service - KDE Session Restoration...
Sep 11 17:08:58 fedora kernel:  dm_ism_commit_idle_optimization_state+0x5b/0x160 [amdgpu]
Sep 11 17:08:58 fedora kernel:  dm_ism_dispatch_power_state+0xee/0x390 [amdgpu]
Sep 11 17:08:58 fedora kernel:  amdgpu_dm_ism_commit_event+0x10d/0x320 [amdgpu]
Sep 11 17:08:58 fedora kernel:  ? finish_task_switch.isra.0+0xc8/0x3d0
Sep 11 17:08:58 fedora kernel:  amdgpu_dm_crtc_vblank_control_worker+0xa1/0xb0 [amdgpu]
Sep 11 17:08:58 fedora kernel:  ? srso_alias_return_thunk+0x5/0xfbef5
Sep 11 17:08:58 fedora systemd[1514]: Starting plasma-startupsound.service - KDE Startup Sound...
Sep 11 17:08:58 fedora kernel:  process_one_work+0x19e/0x370
Sep 11 17:08:58 fedora systemd[1514]: spice-vdagent.service - Spice guest session agent skipped, unmet condition check ConditionPathExists=/run/spice-vdagentd/spice-vdagent-so>
Sep 11 17:08:58 fedora kernel:  worker_thread+0x1a6/0x310
Sep 11 17:08:58 fedora kernel:  ? __pfx_worker_thread+0x10/0x10
Sep 11 17:08:58 fedora kernel:  kthread+0xe4/0x120
Sep 11 17:08:58 fedora kernel:  ? __pfx_kthread+0x10/0x10
Sep 11 17:08:58 fedora kernel:  ret_from_fork+0x1a1/0x270
Sep 11 17:08:58 fedora kernel:  ret_from_fork_asm+0x1a/0x30
Sep 11 17:08:58 fedora kernel:  </TASK>
Sep 11 17:08:58 fedora kernel: ---[ end trace 0000000000000000 ]---
Ah, I can see Spice mentioned in there. Are you running QEMU or a similar VM system?
I am myself trying both technologies on my new FW 13 Pro. It’s not perfect, but I have found it to be stable.
Sadly no.
Ah, it could be that the fedora systemd messages are interspersed in the crash, and it’s the fedora kernel ones you actually want. I would probably next feed a bit of that text into a search engine or an AI chat-window, to see if you can get some hints on the cause. It is likely that someone has posted about it on the web before.
Googling for the error code I only got this and some much older reddit posts:
So not sure if this is the same issue. Overall this still leaves me a bit in the dark since this is not the same kernel version as I have and they didn’t find a solution either.
I wouldn’t trust a chatbot to give me anything usable if there are not even any clear posts/issues that I can find :confused:
So
My searches indicated two things:
  • Your logs are a bit partial, and if you can add some more (prior to these logs) then more detail might emerge;
  • Are you OK with editing the kernel entry at the boot menu? If so, you could try appending amdgpu.dcdebugmask=0x10 - the worst is that it does not improve stability, and you reboot to get rid of it.
I’ve been getting occasional freezes with the 7x40 series lately too. I found this thread on GitLab; I haven’t tried any of the kernel parameter stuff, but running:
sudo cat /sys/kernel/debug/dri/1/amdgpu_gpu_recover
…via an SSH session from my phone has (so far) led to a complete recovery every time, without rebooting or losing any application state. (Sometimes it freezes again a few minutes later, but SSHing in and running the command again fixes it again.)
I think there was something in that thread about a correlation with GNOME’s Night Light, which I have since disabled. I haven’t had a freeze since then, but it hasn’t been long enough to draw any conclusions. I see you’re using KDE, but do you have an equivalent filter set up?
It really does seem to be just the display that freezes—once I was in the middle of a web call when it happened, and I was able to carry on the conversation uninterrupted.
