Pop!_OS
Which release version?
22.04 LTS
Which kernel are you using?
Linux 6.12.10-76061203-generic x86_64
3.20
11th Gen Intel® Core™
Steps to reproduce:
- Replace input cover using Input Cover Kit.
- Observed touchpad is not as responsive as original.
Observations:
- Need to move finger about .5cm or press harder on touchpad before touchpad would recognize input.
Attempted resolutions
- Set touchpad speed to maximum in
Settings > Mouse & Touchpad. - Toggled touchpad off/on in
Disable while typingoff/on inSettings > Mouse & Touchpad. - Installed
gnome-tweaksand toggledDisable While Typingoff/on inTweaks > Keyboard & Mouse > Touchpad.
Successful resolution
- Modified pointer feedback in cli.
xinput set-ptr-feedback "PIXA3854:00 093A:0274 Touchpad" 0.5 2 1 - Touchpad is much more responsive and does not require as much force/finger movement before registering input.
