[RESPONDED] How can I use the new Audio Expansion Card for Stereo-Line-In?
This device seems adequate. I will have a deeper look on it.
Thank you!
Norbert
I bought one of these several years ago to use at a party I was DJ’ing at. I’m not a DJ, its just the proper DJ wanted to charge £250 for the night and we didnt have the funds so I created a 6 hour 70’s 80’s pop/disco tunes list on Spotify, pulled the crossfade to max and used this to hook up to the PA system. Hit shuffle play and away it went all night. DJ’s are overrated!
It had far cleaner and more powerful output than the built in Dell audio, not to mention it was far eaiser using the RCA sockets. It’s spot on for Red Book standard audio which in 99.99% of cases is all that’s needed.
A handy bit of kit to have.
I bought one, and I am happy. It does what I need it for.
Thank you Dino and Jason!
Any updates on this? Do we have a definitive answer whether the audio expansion card can do stereo microphone input?
Somewhere here or on Framework’s subreddit that the audio card is output only. The only input is the mono microphone (TRRS I think)
A definitive answer, as in, one from Framework staff, or someone getting stereo input to work?
I can say at least that I haven’t come across either here on the forum. I’m not active on the Framework subreddit.
This is the chip used
I thought I saw a datasheet available, but I’m not turning up anything now. Maybe what I had seen was for a related chip.
