I’ve been running into an infuriating issue with my FW16 laptop where if I unplug my power adapter from the top-right port where I usually have it plugged in, close the laptop putting it to sleep, the port will be dead when I unlock the machine. The top-left port will work, and I’ve already tried swapping the modules on the sides, and the same thing still happens. This is driving me insane.
Yes this is a bug in the firmware. I just use the left port to charge. I don’t think Framework cares to fix this as they got our money and we are out of warranty by now. There are other bugs to be aware of as well such as a port will stop working if you use a dock, and a port will stop working if you replug the same USB drive in it 3 times in a row.
We have reported these issues to them but they just don’t see fixing their older stuff as any sort of priority I think.
Wow. I thought I was the only one having such issues. I run DIT on my own film sets, and I was absolutely pulling my hair out with bad ports and drives acting up when I had none of these issues on my HP from 2018. And of course support would just put me in circles with the same solutions over and over that wouldn’t work. Good god.
I think this may be related to an issue I’ve been having, but with the read USB-C port on the graphics module:
Short version is: after a lot of back-and-forth with support, it was eventually determined to be a PD issue with AMD’s firmware, and it’s a global issue at that.
If a port stops working, my experience in fixing it has been:
- Turn off your laptop (not just sleep) and unplug it
- Wait about 3-5 minutes
- Keep it unplugged while powering it back on
That should get the port(s) to start working again.
The only thing I can recommend to prevent it from happening is… when shutting off the laptop or putting it to sleep, keep it unplugged.
For whatever reason, being plugged into power while powering on seems to be the cause for ports sometimes being disabled.
And yes, they ARE working with AMD on a fix to this. We don’t know when the fix will come though. Hopefully later this year.
