Dear Framework,
My laptop charger wore out at the location where the charger head bends into an L. Might I make a simple suggestion? Make the cable rotate as it does on some chargers. Thank you
Dear Framework,
Seems like that will put even more of a twisting moment on the connector than the lever moment caused by conventional connectors. There’s a chance that this cable would make things worse, not better. Would need to do some real testing.
Make the head out of jiggly rubber?
