RTX 5070 sitting at zero in Ubuntu while integrated graphics are maxed out
Ubuntu
Which release version?
25.10
Which kernel are you using?
6.17.0-8-generic
04.03
Which Framework Laptop 16 model are you using?
AMD Ryzen™ 7040 Series
Today I fitted my RTX 5070, I have two Ubuntu installs (work and personal) and one Windows 11 install.
  • Windows didn’t recognise the GPU until I had installed new drivers (not mentioned on the installation instructions)
  • Personal Ubuntu was a real nightmare, I ended up upgrading to 25.10 while trying to dig myself out of a hole which wasn’t wise but it’s running smoothly again now
  • Work Ubuntu was pretty easy, I used the UI and enabled the (proprietary, tested) version which doesn’t get in the way
So now comes the question - is it being used?
On Windows I can load up Minecraft with shaders and see the RTX listed in the F3 menu, I can see load being sent to it in the system monitor.
On Linux, I can see it with nvtop, but it’s not being used at all. I installed ollama in order to try some local AI and it put that whole workload on the RTX. I haven’t managed to put any graphical load onto the RTX at all in Linux.
I’ve tried different settings in the Nvidia app, I’ve tried sudo prime-select nvidia, I’ve tried launching Minecraft with a DRI_PRIME=1 environment variable, I’ve tried the same in Spiderman Miles Morales via Steam (based on a Framework guide GitHub - FrameworkComputer/dri_prime1-detection: A simple application to verify if desired applications are running with discrete graphics)
Screenshot attached shows nvtop with the integrated GPU maxing out and the RTX not being used at all.
I can max out the RTX with ollama so it’s clearly working, but not with anything graphical.
Is there a guide to using the RTX card on Ubuntu?
You got 240w charger right?
Since it would need that for rtx 5070 but I could be wrong.
I’m plugged into the same charger for my:
  • Successful windows graphics test
  • Successful Ubuntu AI test
  • Failed Ubuntu graphics test
I don’t think the charger is affecting the outcome.
Try to set the NV MUX to “NV GPU only“ mode in the BIOS.
This worked! Thank you!
I can see myself choosing different options at different times, but I managed to see the RTX being used with graphical stuff :slight_smile:
Have you tried using gpumode to see that hybrid mode is on? GitHub - FrameworkComputer/GPUMode: System tray application for manual GPU mode switching on Ubuntu
Also, when I used hybrid graphics with the 7700S on Ubuntu, I used the context menu on app icon to override the GPU, rather than a an environment variable, and that worked well
I assume trying to run a game in steam?
add:
DRI_PRIME=1 %command%
Or, start an application with the dGPU from your gnome apps:
right click, start with dGPU
Or, start an application from terminal:
$ DRI_PRIME=1 <application_name>
