Sampling of Token Speed - Stock Ubuntu 26.10 - 7.3 Kernel
My batch 14 arrived yesterday- first impression is an amazing machine with underwhelming speakers EasyAudio helps a bit but clips when it gets loud.
On to the benchmarks! this is on an x7 358H with 32GB. Installed 26.10 with no tuning. Asked Claude to benchmark it for a local coding assistant:
These are on the Arc B390 iGPU (Vulkan, llama.cpp build 11972), in tokens per second averaged over 3 runs. “FA” is flash attention. pp512 is how fast it reads a 512-token prompt; tg128 is how fast it generates 128 tokens. “@8K8K” means with 8K tokens already in context.
Model Size FA pp512 tg128 pp51@8K @8K tg128 @8K
Qwen3-Coder-30B-A3B Q4_K_M 17.3 GiB on 465 29.9 51 19.3
off 435 26.4 163 18.3
Qwen3-Coder-30B-A3B Q6_K (8 MoE layers on CPU) 23.4 GiB on 280 17.5 79 12.6
off 285 16.8 142 12.8
Qwen3.6-35B-A3B UD-Q4_K_M 20.6 GiB on 581 24.0 244 21.1
off 625 23.7 496 21.5
Gemma 4 26B-A4B UD-Q4_K_M 15.8 GiB on 578 19.2 109 15.0
off 603 16.2 587 17.4
Devstral Small 2 24B Q4_K_M (dense) 13.3 GiB on 268 5.3 60 4.4
off 285 5.6 165 5.1
For coding in VS Code:
  • Qwen3.6-35B-A3B is the best all-rounder. It’s the newest and largest model here, and it holds about 21 t/s generation and about 500 t/s prompt reading at 8K context. It still fits entirely on the GPU, just barely.
  • Qwen3-Coder Q4_K_M generates fastest with a short context (about 30 t/s), but reads long prompts about 3× slower than Qwen3.6.
  • Gemma 4 reads long prompts fastest (587 t/s at 8K) but generates more slowly.
  • Qwen3-Coder Q6_K isn’t worth it. It’s about 40% slower than the Q4 version and only runs with part of the model on the CPU. A Q6 isn’t usually different enough in quality from a Q4 to make up for that.
  • Devstral Small 2 runs at about 5 t/s. That’s the cost of a dense 24B model on an iGPU: it reads all its weights for every token.
Two things specific to this machine:
  • Start the server with -fa off. It reads prompts at 8K context 2–5× faster on every model.
  • If a model is too big for the GPU, add --no-host 1 along with -ncmoe N. Without it, the experts moved to the CPU go into a pinned buffer that still counts against the GPU’s roughly 23 GB, so the model fails to load no matter how many layers you move.
I saw that Qwen3.8 is on Ollama.
Did you have to do anything special to allow allocation of most of your ram to the gpu?
Nothing special at all:
I didn’t change any driver, BIOS or kernel setting to give the iGPU memory. Every run was a plain llama-bench call from ~/Downloads/llama-b11972, through a small wrapper script at ~/models/bench/run.sh:
./llama-bench -m <model.gguf> -fa on,off -p 512 -n 128 -d 0,8192 -r 3 -o jsonl
What the options do:
  • -fa on,off: tests with flash attention on, then off
  • -p 512 -n 128: reads a 512-token prompt, then generates 128 tokens
  • -d 0,8192: runs every test twice, once with an empty context and once with 8K tokens already in it
  • -r 3: repeats each test 3 times and averages
  • No -ngl: the default puts every layer on the GPU
The one exception was Qwen3-Coder Q6_K, which needed two extra flags:
./llama-bench -m ~/models/Qwen3-Coder-30B-A3B-Instruct-Q6_K.gguf -ncmoe 8 --no-host 1 -t 8 -fa on,off -p 512 -n 128 -d 0,8192 -r 3
  • -ncmoe 8: keeps the expert weights of 8 layers on the CPU
  • --no-host 1: puts those CPU weights in ordinary RAM instead of a pinned buffer that still counts against the GPU’s limit
  • -t 8: gives the CPU part 8 threads instead of the default 2
How the GPU gets its memory: the Arc B390 has no memory of its own. It shares your 30 GB of system RAM, and the Linux xe driver lets it use up to about 23 GB of that by default. llama.cpp’s Vulkan backend reports this at startup as Vulkan0: Intel(R) Arc(tm) B390 (PTL) (23336 MiB, …free), and you can check it yourself with:
Isn’t Gemma4 newer than Qwen3.6?
