Screen flickering framework 13 pro
Hello framework community!
I have quite severe screen flickering that comes and goes randomly. Anybody have ideas how to solve this?
Any help is appreciated, thanks.
System Details Report
Report details
  • Date generated: 2026-10-19 11:31:53
Hardware Information:
  • Hardware Model: Framework Laptop 13 Pro Intel Core Ultra Series 3
  • Memory: 32.0 GiB
  • Processor: Intel® Core™ Ultra X7 358H × 16
  • Graphics: Intel® Arc™ B390 (PTL)
  • Disk Capacity: 2.0 TB
Software Information:
  • Firmware Version: 03.02
  • OS Name: Fedora Linux 44 (Workstation Edition)
  • OS Build: (null)
  • OS Type: 64-bit
  • GNOME Version: 50
  • Windowing System: Wayland
  • Kernel Version: Linux 7.2.11-200.fc44.x86_64
Can you post a link to a video showing the flickering. Different looking flicker means different things.
A good first step is to boot into the BIOS and see if you still have a problem. If you do not, then there’s a chance it’s your operating system rather than a hardware fault.
There is no flicker in the BIOS, but I have Fedora installed which I thought was officially supported.
flicker_full_resolution_60fps
The video shows the “flickering” in the slight brightness changes that you see best on the t-shirt and the blue background in the second part.
Super! It think that means your hardware is OK.
Would you add some commentary on your video? The mobile phone is probably moving around too fast for readers to see what you are referring to. Is the flicker visible in the video? I can’t see it myself. Is it a moderate dimming rather than a complete screen blackness?
Next I would suggest putting a different distro on a memory stick (e.g. Ubuntu) and seeing if that has the flicker. You should be able to do that from a Live distro i.e. you don’t need to do a full install. Try to set the resolution to what you normally would use in Fedora (the BIOS will use a very low resolution, so it is a good first test, but not an ideal one).
To be clear, I am not dissuading you from using Fedora: I think you just need to narrow down the potential cause, and to fully eliminate hardware problems. Per my earlier comment, I currently suspect a driver problem.
Make sure that HDR is disabled in your display settings. Apparently the display panel does not support HDR but somehow the setting still shows up in the settings.
I saw the video.
A setting that is worth trying is disable “automatic screen brightness” in the power settings.
seconding @james3 here. Using Ubuntu + Gnome and the "automatic screen brightness was hidden under power > power savings
disable HDR and Adaptive Backlight Modulation (ABM, not the same as adjusting brightness automatically based on ambient light)
Yes I have noticed it using any chromium based Browers. While exiting full screen mine flickers a half second or so after. I switched to Firefox and its semi resolved. (Happened last night changing taskbar settings, so not only browser related)
Was also going to make a post about it. I was on linux mint and no issues. But since switching to fedora KDE I’ve noticed it
Quick update:
  1. Disabled both auto brightness and hdr. Problem seems less frequent but still there
  2. Will test different distro via usb boot when I come around to it
  3. ABM seems to be amd specific? Found this: For Intel processors, the equivalent feature is called Intel Display Power Saving Technology (DPST) or Panel Self Refresh (PSR)
Thanks all for the support!
I had the exact same issue with my day old 13 pro with virtually the same specs as yours, also Fedora 44. The flickering was particularly bad with HDR on, but still noticeable off - and would only decrease when either moving the mouse or watching videos. There was also no flickering at all in BIOS. I also had a momentary visible display artifact on login.
I managed to disable Panel Self Refresh but it didn’t make an immediate difference. I realised I had been solely on battery so tested on power by plugging into an external display and the flickering immediately stopped. I disconnected from power and it remained flicker free… I really don’t know what might have happened
Thank you for the report Dominic!
Could this be some sort of static issue? I have no flickering when I have turned off the machine for a while. And I use a random GaN charging brick from Aukey without a ground pin.
But is it workable for you like this?
Could be, I really have no idea. All i know is that I still haven’t had further flickering or artifact issues since that moment briefly plugging into a power source…
I’ve also re-enabled PSR, on the 1 setting, and everything still ran perfectly.
I just set it back to the default -1 setting for the first time and on reboot, just after login, there was a severe artifact (entire screen multicoloured glitch) which disappeared when i moved the mouse. The flickering is still gone, and I did another test reboot and no further artifacts occurred, so I’m leaving PSR as -1. I hope that’s it for both of us!
Hi,
I have noticed flicker like that here.
Does it only appear in videos viewed in a web browser?
I.e. if you watch the video, while not full screen, does the whole screen flicker, or just the video parts of the screen.
What I see, is changes in the brightness of some of the video frame and not other parts.
If I instead watch a video in Linux with “mpv”, it does not flicker like in Firefox or Chrome.
So, this might be related to video playback in a web browser, as opposed to a hardware problem.
It might also be very difficult to reproduce, as it might only show when a particular video bandwidth is used.
Please can you post a URL to the actual video you are watching there, so maybe others can reproduce the problem.
The video I see showing the problem is this one:
That’s interesting, do you have HDR enabled? I have kept HDR enabled and I’ve just replicated my flickering issue by watching a film on mubi.com (I don’t know what codec I was streaming, but I understand they use Google Widevine for DRM).
Youtube has been completely fine for me including your video, but streaming on Mubi using Brave browser caused the flickering to start again on the video player which then continued throughout the OS even after I had closed the video. I tested changing my PSR from -1 to 1 but it didn’t help. Then I changed it to 0, and that caused login issues on reboot, so I changed back to -1, turned HDR off, and the film streamed on Mubi without flickering.
So I think my issue is just down to the known HDR bug in Fedora, and my workaround is just to disable it when I encounter applications that trigger flickering
Sorry for reviving almost dead thread but I’ve had the very faint flickering on my 13Pro twice now. The first time it sort of fixed it self, I don’t know what happened. This time, I disabled psr using grubby as well as disabled panel replay. It’s disappointing that Fedora still has these quirks. Can we just get a fool-proof open source OS already pls! lol
