Hey there,
Since I’m travelling quite a lot and oftentimes work without access to a proper screen I would love to be able to raise the screen. I know there are laptop stands but a lot of them create an awkward angle, are too bulky or just too flimsy to type on.
How difficult would it be to do the following
- Make it possible to separate the screen and have some form av extension cable
- use a simple tripod (which I already have) to elevate the screen to a more ergonomically sound position
Any thoughts appreciated
I like this idea. I wonder if it would be easier to make the keyboard detachable instead and elevate the monitor
There are some very small Bluetooth keyboards. If that appeals to you.
I have a foldable that is about the size of my phone
So remove the keyboard and lift up the “motherboard” + monitor? I kinda like the mechanical keyboard + framework motherboard in a kit option but in that case I would require a portable monitor.
Afraid I’m a keyboard snob
, so more likely that i’ll drag along a mechanical keyboard if anything.
Me too, my MX Mechanical connects nicely with Bluetooth
I use the foldable with my phone, under duress.
Grab this keyboard and folder looking thingy, smack the FL on it and call it a day.
