I see that you offer only single speed RAM. Is this since you operate under the conclusion, that customers of this device will not notice the speed difference between a RAM that is halved in performance?
Considering the RAM prices these days, would a 2x 4GB memory be quite fitting, and 2x 8GB would probably still be a sensible choice. But just leaving it to the customer to figure that out, and not even mentioning the speed difference in the FAQ, feels a little off.
I’m not sure you will get the answer you want here - this forum is mostly a bunch of FW-12 owners, although sometimes a FW employee chimes in.
Interestingly, the processor in the original (2025) version could have supported 2 sticks of ram (dual channel) if they had put two slots on the motherboard, but as @jcdenton points out, in the new version the processor only supports single channel.
I think lots of the FW-12 owners have one or two things they wish FW had done differently - I’d have preferred dual channel ram too. In the end, I bought a FW for the repairability and upgradeability, and the 12 was the best fit of their machines for my needs.
Yes, the FW 12 only has one slot. However, it is possible to buy any FW laptop, and not be aware of the drawbacks of running in single-channel mode. I made a suggestion here on how customers could be “nudged” in the configuration workflow:
However, I should think HQ are completely maxed-out at present, and I doubt this will get onto the radar.
