I’m using Fedora 42 KDE, fully up-to-date.
My order: https://frame.work/nl/en/share-my-laptop?token=89574d3e931
When I first installed Fedora 42 KDE on my new FW16 just a week ago, it did work, albeit only after initial login. But it doesn’t work anymore. I just now updated firmware from 3.05 to .07, but that didn’t make a difference.
The dialog to add fingerprints work, but the actual sensor input does not.
Vendor: INSYDE Corp.
Version: 03.07
Release Date: 08/27/2025
Address: 0xE0000
product: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics
vendor: Advanced Micro Devices [AMD]
physical id: 4
bus info: cpu@0
version: 25.116.1
I don’t know if it makes a difference, but I also notice that often my laptop stays on while the lid is closed, but sometimes it will go to sleep. More often not though.
A minor item is that the numpad takes a while to get right after reboot? When I try to use it too early, the [enter] cycles through back-light brightness, and the + turns it off/on. After a while though it switches to expected behavior.
So if someone can help me chase down the sleep and fingerprint issues, I’d really appreciate it.
