Nag
September 4, 2025, 3:34pm
1
Hi all, just received my 2 FW12 very happy they both work very well but for one exception (on both).
I am running windows 11 on both but when I change the sleep setting for a longer period they both still fall asleep within a few minutes. Both laptop are at full battery and plugged in.
I tried various timing (30 minutes to never)
Any suggestions?
JC11
September 4, 2025, 8:46pm
2
There could be some confusion here between screen blank and sleep. Try changing the screen blank settings too.
Also don’t ask how, I don’t use windows.
Nag
September 4, 2025, 10:57pm
3
Thanks JC11 but no go.
BTW I’m also learning Mint & Ubuntu so noob here also
Tesseus
September 5, 2025, 1:10am
4
How many minutes before it goes idle for you? I can’t test yet since I’m still running memtest but I can test to see if mines go idle too after.
Nag
September 5, 2025, 2:42am
5
Hi Tesseus
When I don’t touch anything about 1 minute ± then the screen saver comes on.
Nag
September 5, 2025, 3:23am
6
I have found out the issue and it has been resolved.
Thankyou for your time. It was a windows 11 issue, a setting that I missed.
Go to….
Settings
Personalization
Lock screen
Screen saver ( I used bubbles)
In the box WAIT, I use 400 minutes and the Checked box (On resume, display logon screen)
Then Apply.
Also, I applied this
I change the sleep setting for a longer period 3 hours
With all the things that I checked, and did, I hope that this is the solution.
I just repeated this solution on my wife’s Framework Laptop 12 as well. And it worked.
system
Closed
September 7, 2025, 3:24am
7
