Slow phone charging from Framework 12
Operating System: Fedora Linux 44 (KDE)
KDE Plasma Version: 6.7.5
KDE Frameworks Version: 6.30.0
Qt Version: 6.11.2
Kernel Version: 7.2.8-200.fc44.x86_64 (64-bit)
Processors: 8 × 13th Gen Intel® Core™ i3-1315U
Product Name: Laptop 12 (13th Gen Intel Core)
Phone: CMF phone 2 Pro, by Nothing
OS: Nothing OS 4.1 (Galaga-B4.1-260812-1729-EEA)
Android version: 16
I’m using Nothing’s cable, which they include with the phone, and can handle both charging the phone at 33Watt over PPS and charging my FW 12. I have also tested with other generic cables that have the same capabilities, with no change in results.
As the title mentions, my phone charges very slowly from my Framework 12, only just breaking even and charging at ~.1-.3A. On average, it draws around 4Watts, so I total this up to charging at about 1A total. I don’t have an actual power meter to test this though.
By using a combination of framework_tool and looking at files under /sys/class/typec I can tell that my phone does negotiate for 5V, 3A charging sometimes. It will either negotiate 2A or 3A. I’ve not spotted a pattern in this yet though.
I have made sure to turn data transfer off via usb off on my android, and have also tried switching to the laptop controlling the connection.
For example, I plug my phone in once:
USB-C Port 3:
  PD Contract:   Yes
  Power Role:    Source
  Data Role:     Dfp
  VCONN:         On
  Negotiated:    5.000 V, 2000 mA, 10.0 W
Unplug, and replug into the same port:
USB-C Port 3:
  PD Contract:   Yes
  Power Role:    Source
  Data Role:     Dfp
  VCONN:         On
  Negotiated:    5.000 V, 3000 mA, 15.0 W
Both times, my phone stays charging very slowly, and there seems to not be a difference between the two.
Im using the Accubattery app to view the power stats.
My main questions is if this has been seen often by others, if there’s anything else I should try, and if this is more likely a phone side issue (I fear it is).
I’ve attached a framework tool diagnostic log as well, if anyone would like any more system info:
Framework Complete Diagnostic Bundle
Generated: Wed  7 Oct 07:36:28 BST 2026
=== PLATFORM DETECTION ===
Product: Laptop 12 (13th Gen Intel Core)
Version: A3
Manufacturer: Framework
Serial: FRAPDACPA35511001N
BIOS Version: 03.09
BIOS Date: 08/20/2026
=== CPU INFORMATION ===
model name	: 13th Gen Intel(R) Core(TM) i3-1315U
CPU Cores: 8
=== GPU DETECTION ===
00:02.0 VGA compatible controller: Intel Corporation Raptor Lake-P [UHD Graphics] (rev 04)
=== MEMORY INFO ===
               total        used        free      shared  buff/cache   available
Mem:            15Gi       4.6Gi       4.1Gi       1.1Gi       8.0Gi        10Gi
Swap:          8.0Gi       433Mi       7.6Gi
=== STORAGE DEVICES ===
NAME                                            SIZE TYPE  MOUNTPOINT FSTYPE
zram0                                             8G disk  [SWAP]     swap
nvme0n1                                       476.9G disk
├─nvme0n1p1                                     600M part  /boot/efi  vfat
├─nvme0n1p2                                       2G part  /boot      ext4
└─nvme0n1p3                                   474.4G part             crypto_LUKS
  └─luks-6e24ea5d-d402-4e2c-bf3a-8f6ddaf7f0e8 474.3G crypt /home      btrfs
=== WIRELESS DEVICES ===
=== KERNEL INFO ===
Linux fedora 7.2.8-200.fc44.x86_64 #1 SMP PREEMPT_DYNAMIC Fri Sep 25 21:05:44 UTC 2026 x86_64 GNU/Linux
=== LOADED KERNEL MODULES (TOP 20) ===
ac97_bus               12288  1 snd_soc_core
acpi_pad              184320  0
acpi_thermal_rel       24576  1 int3400_thermal
binfmt_misc            28672  1
bluetooth            1208320  44 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
bnep                   36864  2
btbcm                  24576  1 btusb
btintel                86016  1 btusb
btmtk                  40960  1 btusb
btrtl                  40960  1 btusb
btusb                  90112  0
cdc_ether              28672  1 rndis_host
cec                   110592  3 drm_display_helper,xe,i915
cfg80211             1691648  3 iwlmvm,iwlwifi,mac80211
coretemp               24576  0
crc8                   12288  1 soundwire_cadence
cros_charge_control    16384  0
cros_ec                20480  1 cros_ec_lpcs
cros_ec_chardev        24576  0
cros_ec_dev            20480  0
=== FIRMWARE STATUS ===
Status: ✅ No firmware load failures detected
=== DRIVER BINDINGS ===
00:02.0 VGA compatible controller [0300]: Intel Corporation Raptor Lake-P [UHD Graphics] [8086:a7a9] (rev 04)
	Subsystem: Framework Computer Inc. Device [f111:000c]
	Kernel driver in use: i915
	Kernel modules: i915, xe
00:14.3 Network controller [0280]: Intel Corporation Raptor Lake PCH CNVi WiFi [8086:51f1] (rev 01)
	Subsystem: Intel Corporation Device [8086:0094]
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
=== FRAMEWORK TOOL: FIRMWARE VERSIONS ===
Tool Version:     0.6.6
OS Version:       Linux 7.2.8-200.fc44.x86_64 #1 SMP PREEMPT_DYNAMIC Fri Sep 25 21:05:44 UTC 2026 x86_64
Mainboard Hardware
  Type:           Laptop 12 (13th Gen Intel Core)
  Revision:       MassProduction
UEFI BIOS
  Version:        03.09
  Release Date:   08/20/2026
EC Firmware
  Build version:  sunflower-3.0.9-9a48264 2026-08-18 09:00:15 lotus@ip-172-26-3-226
  Current image:  RO
PD Controllers
  Right (01):       0.0.12 (MainFw)
  Left  (23):       0.0.12 (MainFw)
Intel Retimers (Potential)
  GUID:          0F74C56D-D5BA-4942-96FA-D37560F40554
  Version:       0xACD (2765)
CSME
  Firmware Version: 0:16.1.40.2765
  Recovery Ver:     0:16.1.40.2765
  Original Ver:     0:16.1.32.2473
Framework Laptop 12 Webcam Module
  Firmware Version: 0.1.6
Touchpad
  Firmware Version: v0E08
Touchscreen
  Firmware Version: v7.0.0.5.0.0.0.0
  Protocols:        USI
NVMe Device: /dev/nvme0 (nvme)
  Model Number:     BC711 NVMe SK hynix 512GB
  Serial Number:    FYB5N036212705R0G
  Firmware Version: 41002131
=== FRAMEWORK TOOL: POWER STATUS (DETAILED) ===
Battery Cutoff:     Unknown
Charger Status
  AC is:            not connected
  Charger Voltage:  12592mV
  Charger Current:  0mA
                    0.00C
  Chg Input Current:384mA
  Battery SoC:      87%
Battery Status
  Battery is:       connected
  Battery LFCC:     4345 mAh (Last Full Charge Capacity)
  Battery Capacity: 3742 mAh
                    46.913 Wh
  Charge level:     86%
  Manufacturer:     ATC
  Model Number:     FRANDZG
  Serial Number:    073D
  Battery Type:     LION
  Present Voltage:  12.537 V
  Present Rate:     1107 mA
  Design Capacity:  4265 mAh
                    49.772 Wh
  Design Voltage:   11.670 V
  Cycle Count:      44
  Battery discharging
=== FRAMEWORK TOOL: THERMAL STATUS ===
  cpu_f75303@4d:      47 C
  top_skin_f75303@4d: 41 C
  local_f75303@4d:    35 C
  battery_temp@b:     26 C
  peci-temp:          73 C
  charger_temp@9:     30 C
  APU Fan:            2649 RPM
  AP Throttle Status
    Soft (AMD SPPT):  false
    Hard (PROCHOT#):  false
=== FRAMEWORK TOOL: USB-C PD PORTS ===
USB-C Port 0:
  PD Contract:   No
  Power Role:    Sink
  Data Role:     Ufp
USB-C Port 1:
  PD Contract:   Yes
  Power Role:    Source
  Data Role:     Dfp
  VCONN:         Off
  CC Polarity:   CC1
  Port Partner:  Sink
  EPR:           Inactive
USB-C Port 2:
  PD Contract:   No
  Power Role:    Sink
  Data Role:     Ufp
USB-C Port 3:
  PD Contract:   No
  Power Role:    Sink
  Data Role:     Ufp
=== FRAMEWORK TOOL: PD CONTROLLER INFO ===
Right / Ports 01
  Silicon ID:     0x30A0
  Mode:           MainFw
  Flash Row Size: 128 B
  Ports Enabled:  0, 1
  Bootloader Version:   Base: 3.3.63.001,  App: 0.0.02
  FW1 (Backup) Version: Base: 3.7.0.09F,  App: 0.0.12
  FW2 (Main)   Version: Base: 3.7.0.09F,  App: 0.0.12
Left / Ports 23
  Silicon ID:     0x30A0
  Mode:           MainFw
  Ports Enabled:  0, 1
Back
  Failed to read Silicon ID/Family
=== FRAMEWORK TOOL: EC CONSOLE (RECENT 50 EVENTS) ===
[232105.900500 event set 0x0400000000000000]
PORT80: 003B
[232106.890200 event set 0x0400000000000000]
[232106.909600 event set 0x0400000000000000]
[232106.903800 HC 0x3e23]
+[232106.945400 event set 0x0400000000000000]
++[232106.978800 event set 0x0400000000000000]
[232106.994400 base-accel Missed 0 data collections at 178740416 - rate: 80000]
PORT80: 003B
[232107.820800 Battery 89% (Display 88.4 %) / 5h:23 to empty]
[232132.862100 Battery 89% (Display 88.3 %) / 5h:36 to empty]
[232152.251200 Battery 89% (Display 88.2 %) / 5h:14 to empty]
[232171.263500 Battery 89% (Display 88.1 %) / 5h:9 to empty]
[232193.618200 Battery 89% (Display 88.0 %) / 4h:50 to empty]
[232211.651000 Battery 89% (Display 87.9 %) / 4h:48 to empty]
[232215.406400 Battery 88% (Display 87.9 %) / 4h:44 to empty]
[232230.931200 Battery 88% (Display 87.8 %) / 5h:4 to empty]
[232253.972000 Battery 88% (Display 87.7 %) / 4h:59 to empty]
[232272.246300 Battery 88% (Display 87.6 %) / 4h:52 to empty]
[232290.282300 Battery 88% (Display 87.5 %) / 4h:53 to empty]
[232313.466200 Battery 88% (Display 87.4 %) / 4h:55 to empty]
[232333.754200 Battery 88% (Display 87.3 %) / 5h:0 to empty]
[232351.786000 Battery 88% (Display 87.2 %) / 4h:56 to empty]
[232375.850700 Battery 88% (Display 87.1 %) / 5h:2 to empty]
[232397.134000 Battery 88% (Display 87.0 %) / 5h:28 to empty]
[232416.166500 Battery 88% (Display 86.9 %) / 5h:12 to empty]
[232421.174500 Battery 87% (Display 86.9 %) / 5h:9 to empty]
[232441.459300 Battery 87% (Display 86.8 %) / 5h:12 to empty]
[232459.739800 Battery 87% (Display 86.7 %) / 4h:41 to empty]
[232478.774100 Battery 87% (Display 86.6 %) / 4h:16 to empty]
[232494.799200 Battery 87% (Display 86.5 %) / 4h:10 to empty]
[232509.072700 Battery 87% (Display 86.4 %) / 3h:45 to empty]
[232525.111700 Battery 87% (Display 86.3 %) / 3h:36 to empty]
[232538.380100 Battery 87% (Display 86.2 %) / 3h:23 to empty]
[232550.399200 Battery 87% (Display 86.1 %) / 3h:15 to empty]
[232563.950400 HC 0x0004]
[232563.952500 HC 0x3e01]
[232563.953900 HC 0x0002]
[232563.956100 HC 0x3e01]
[232563.957500 HC 0x009e]
+++(++)[232563.972600 HC 0x3e1e]
[232563.974300 HC 0x3e1e err 1]
[232564.139800 HC 0x3e21]
[232564.141000 HC 0x3e21 err 1]
[232564.142600 HC 0x00a0]
[232564.147200 HC 0x0070]
+++(++)[232564.154300 HC 0x3e22]
[232564.159500 HC 0x3e23]
+++[232564.171300 HC 0x009e]
=== ADDITIONAL SENSORS (lm-sensors) ===
ucsi_source_psy_USBC000:003-isa-0000
Adapter: ISA adapter
in0:           0.00 V  (min =  +0.00 V, max =  +0.00 V)
curr1:         0.00 A  (max =  +0.00 A)
cros_ec-isa-0000
fan1:               2649 RPM
cpu_f75303@4d:       +46.9°C  (high = -273.1°C, crit = +74.8°C)
                              (emerg = +84.8°C)
top_skin_f75303@4d:  +40.9°C  (high = -273.1°C, crit = +79.8°C)
                              (emerg = +89.8°C)
local_f75303@4d:     +34.9°C  (high = -273.1°C, crit = +83.8°C)
                              (emerg = +93.8°C)
battery_temp@b:      +25.9°C  (high = -273.1°C, crit = +60.9°C)
                              (emerg = +65.8°C)
peci-temp:           +72.8°C  (high = +114.8°C, crit = +119.8°C)
                              (emerg = +126.8°C)
charger_temp@9:      +29.9°C  (high = -273.1°C, crit = -273.1°C)
                              (emerg = -273.1°C)
ucsi_source_psy_USBC000:001-isa-0000
spd5118-i2c-17-50
Adapter: SMBus I801 adapter at 0000:00:1f.4
temp1:        +41.0°C  (low  =  +0.0°C, high = +55.0°C)
                       (crit low =  +0.0°C, crit = +85.0°C)
nvme-pci-0100
Adapter: PCI adapter
Composite:    +29.9°C  (low  =  -0.1°C, high = +82.8°C)
                       (crit = +84.8°C)
Sensor 1:     +30.9°C  (low  = -273.1°C, high = +65261.8°C)
Sensor 2:     +36.9°C  (low  = -273.1°C, high = +65261.8°C)
acpitz-acpi-0
Adapter: ACPI interface
temp1:        +72.8°C
temp2:        +40.9°C
temp3:        +34.9°C
temp4:        +46.9°C
temp5:        +26.6°C
ucsi_source_psy_USBC000:004-isa-0000
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1:        +39.0°C
ucsi_source_psy_USBC000:002-isa-0000
in0:           5.00 V  (min =  +5.00 V, max =  +5.00 V)
curr1:         3.00 A  (max =  +1.30 A)
coretemp-isa-0000
Package id 0:  +59.0°C  (high = +100.0°C, crit = +100.0°C)
Core 0:        +52.0°C  (high = +100.0°C, crit = +100.0°C)
Core 4:        +52.0°C  (high = +100.0°C, crit = +100.0°C)
Core 12:       +58.0°C  (high = +100.0°C, crit = +100.0°C)
Core 13:       +58.0°C  (high = +100.0°C, crit = +100.0°C)
Core 14:       +58.0°C  (high = +100.0°C, crit = +100.0°C)
Core 15:       +59.0°C  (high = +100.0°C, crit = +100.0°C)
BAT1-acpi-0
in0:          12.44 V
curr1:         1.12 A
acpi_fan-isa-0000
fan1:        2649 RPM
power1:           N/A
Diagnostic bundle complete!
Output saved to: fw_diagnostic_20261007_073628.log
This file contains:
  • Platform detection (model, BIOS, motherboard)
  • Hardware enumeration (CPU, GPU, storage, RAM, WiFi)
  • Kernel version and compatibility check
  • Firmware load status and driver bindings
  • Framework Tool diagnostics (versions, power, thermal, USB-C PD, EC console)
Attach this file to Framework Support tickets for fastest assistance.
I think 10 or 15Watts is going to be very slow. I don’t think any FW is designed to charge devices. Only to power then just enough to work.
Sure, but its in theory the same speed as USB-A, which definitely charges a phone. Meanwhile, if i turn my screen on it actually discharges.
James is right on about the phone charging from the laptop.
Speed and power delivery are not the same over USB though.
In order to get the higher charging output a device has to negotiate a higher draw from the port in this case the Framework laptop.
Since the laptop is designed to be a power sink primarily instead of a power bank most of the way the ports are coded is to conserve power so the laptop lasts the longest.
So the basic power it does provide should be enough to slowly charge a phone, though some newer phones automatically just assume “oh great I am powered by a charger, let’s go all out!” And the normal conservative state of a phone set aside because again it takes on a different profile when charging vs. when it is on battery.
Same thing as the Framework Laptop, when charging the power profiles are different. Could that be changed so when a Framework device is plugged in it can enable higher over its USBC ports? Sure, maybe log a feature request so they know others are interested in doing this with their setups.
Some laptop manufacturers even have settings in their bios to turn on or off extra power delivery or even provide charging when the laptop is off. Though it all will take a toll on the battery ultimately.
With as fast as some of the newer phones can take a charge today, unplugging the USBC from the Framework and charging a phone for even 15 minutes can really boost the charge in a short period of time. Like 30W vs 15W. Then when the phone is topped off, plug the cable back into the laptop.
Just some different ways to accomplish the end result.
I totally understand everything you’re saying, but I don’t think this is a case of the laptop advertising up to 3A, but actually limiting output to 1A. I’m not sure why Framework would specifically make the FW12 be able to negotiate up to 15W PD on a port if it was actually limited to 5W.
My phone definitely does move to a higher power profile when plugged in, but i have confirmed that my estimate of 4 Watt Power draw is correct. Using the one USB-A wall plug I do have (which also has a built in power meter) I’ve confirmed that my phone can charge at 15W+ off of 5V. When it’s drawing 16W from the wall, Accubattery shows a net positive of 12.5W.
The wall plug does have a limit of 20W on usb-a, as opposed to the FW12’s 15W limit, but it confirms that my phone can charge up to 15W and draws an average of 4W when plugged in.
I can’t rule out that the phone treats USB-A and USB-C PD differently without a USB-C PD source to test against, but it clearly can do 15W at 5V.
All of my wall plugs also support PPS, so the phone fast charges with 9V, at ~30W.
I’d also like to clarify that my reason for looking into this is so I know I have a backup power supply, for when my trains’ plugs aren’t working (which is annoyingly common) and I’ve not got/not charged a power bank.
I would be interested to test if the phone can pull 15W with a USB-A expansion card, but don’t have one to test with.
If I don’t figure it out in the next few days, I’ll probably go straight to Framework, but wanted to see if anyone else knew about this first ^^
This is probably due to the phone or cable resistance.
If possible, use a PD negotiation decoy cable and use a dummy load to draw 3A
Ahh I understand better now. I thought it was only on a USB A expansion card that the 5W was happening.
Might be a good idea to put in a ticket through support and ask them if they can say what conditions are necessary to get the 15W out of a port.
Finding a power source while on transport can be hit or miss sometimes. Even if there is one it does not always work. I know others have gotten a larger power bank (25k?) that has USBC PD output and used that to supplement the Framework laptop battery or top it up when AC power is not available.
I know the Framework Laptop 13 11th gen I have can charge over 15W albeit slowly. At that level it is mostly just maintaining the charge level under basic use.
