Fedora 43
Laptop 13, AMD 7040 Series
I tried to contact support 3 times and after submitting I kept getting an error from the web page so decided to get support here.
I got this error so ran a check
SMART Disk monitor: Device: /dev/nvme0, Critical Warning (0x04): Reliability
Seems like the results are say its really new and is failing prematurely.
I’m not sure if i need to get warranty through framework or directly from western digital?
Any guidance is apprecated.
sudo smartctl -a /dev/nvme0
smartctl 7.5 2025-04-30 r5714 [x86_64-linux-7.0.14-101.fc43.x86_64] (local build)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number: WD_BLACK SN770 1TB
Serial Number: 241623800296
Firmware Version: 731100WD
PCI Vendor/Subsystem ID: 0x15b7
IEEE OUI Identifier: 0x001b44
Total NVM Capacity: 1,000,204,886,016 [1.00 TB]
Unallocated NVM Capacity: 0
Controller ID: 0
NVMe Version: 1.4
Number of Namespaces: 1
Namespace 1 Size/Capacity: 1,000,204,886,016 [1.00 TB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 001b44 8b47d2dac2
Local Time is: Mon Jul 13 08:48:59 2026 PDT
Firmware Updates (0x14): 2 Slots, no Reset required
Optional Admin Commands (0x0017): Security Format Frmw_DL Self_Test
Optional NVM Commands (0x00df): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp Verify
Log Page Attributes (0x7e): Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg Pers_Ev_Lg Log0_FISE_MI Telmtry_Ar_4
Maximum Data Transfer Size: 256 Pages
Warning Comp. Temp. Threshold: 84 Celsius
Critical Comp. Temp. Threshold: 88 Celsius
Namespace 1 Features (0x02): NA_Fields
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 5.00W 5.00W - 0 0 0 0 0 0
1 + 3.30W 3.00W - 0 0 0 0 0 0
2 + 2.20W 2.00W - 0 0 0 0 0 0
3 - 0.0150W - - 3 3 3 3 1500 2500
4 - 0.0050W - - 4 4 4 4 10000 6000
5 - 0.0033W - - 5 5 5 5 176000 25000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 2
1 - 4096 0 1
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
NVM subsystem reliability has been degraded
SMART/Health Information (NVMe Log 0x02, NSID 0xffffffff)
Critical Warning: 0x04
Temperature: 39 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 1%
Data Units Read: 8,757,046 [4.48 TB]
Data Units Written: 59,660,946 [30.5 TB]
Host Read Commands: 73,456,829
Host Write Commands: 1,020,470,541
Controller Busy Time: 2,948
Power Cycles: 329
Power On Hours: 1,171
Unsafe Shutdowns: 123
Media and Data Integrity Errors: 11
Error Information Log Entries: 11
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 53 Celsius
Temperature Sensor 2: 39 Celsius
Error Information (NVMe Log 0x01, 16 of 256 entries)
Num ErrCount SQId CmdId Status PELoc LBA NSID VS Message
0 11 9 0x10ad 0xc502 - 41846848 1 - Unrecovered Read Error
1 10 7 0x72c8 0xc502 - 39749704 1 - Unrecovered Read Error
2 9 7 0x42c7 0xc502 - 41846848 1 - Unrecovered Read Error
3 8 7 0xd2c6 0xc502 - 39749704 1 - Unrecovered Read Error
4 7 1 0xa016 0xc502 - 41846848 1 - Unrecovered Read Error
5 6 1 0x2015 0xc502 - 39749704 1 - Unrecovered Read Error
6 5 7 0xc2c5 0xc502 - 41846848 1 - Unrecovered Read Error
7 4 7 0x12c4 0xc502 - 39749704 1 - Unrecovered Read Error
8 3 4 0x4257 0xc502 - 39756448 1 - Unrecovered Read Error
9 2 9 0x10ac 0xc502 - 41846848 1 - Unrecovered Read Error
10 1 9 0x20ab 0xc502 - 39749704 1 - Unrecovered Read Error
Self-test Log (NVMe Log 0x06, NSID 0xffffffff)
Self-test status: No self-test in progress
No Self-tests Logged
