[Solved] Fix for screen tearing with kernel 7.0.0-38 and amdgpu
Posting this for others to find.
Which Linux distro are you using? Linux Mint 22.3
Which release version? Cinnamon using X11
Which kernel are you using? 7.0.0-38 generic
Which BIOS version are you using? 4.2
Which Framework Laptop 13 model are you using? AMD Ryzen™ AI 300 Series
I solved the screen tearing (random static artifacts) by following this Reddit post How I fixed screen tearing on Cinnamon/Mint 22.3/AMD GPU which the Gentoo AMDGPU page also details.
Add this content to /etc/X11/xorg.conf.d/20-amdgpu.conf:
Section "Device"
     Identifier "AMD"
     Driver "amdgpu"
     Option "TearFree" "true"
EndSection
Create the file if it doesn’t already exist or just add the Option "TearFree" "true" line if there already is that section.
You’ll need to use sudo, so either:
sudo vim /etc/X11/xorg.conf.d/20-amdgpu.conf
or
sudo nano /etc/X11/xorg.conf.d/20-amdgpu.conf
