@Matt_Hartley What I did before that could have induced this state:
rmmod
ed all my nvidia* kernel modules
- unplugged my eGPU (it was not used by Xorg, only for compute, so unplugging is possible as long as the nvidia kernel modules are not loaded)
- unplugged my thunderbolt Anker 577 dock
I think this excerpt of dmesg -t
starts around the time when I unloaded the nvidia
drivers:
cros_ec_lpcs cros_ec_lpcs.0: packet too long (773 bytes, expected 0)
perf: interrupt took too long (3921 > 3918), lowering kernel.perf_event_max_sample_rate to 51000
cros_ec_lpcs cros_ec_lpcs.0: packet too long (4 bytes, expected 0)
[drm] [nvidia-drm] [GPU ID 0x00000400] Unloading driver
nvidia-modeset: Unloading
nvidia-uvm: Unloaded the UVM driver.
nvidia-nvlink: Unregistered Nvlink Core, major device number 509
thunderbolt 0-0:1.1: retimer disconnected
thunderbolt 0-1: device disconnected
pcieport 0000:00:07.0: pciehp: Slot(3): Link Down
pcieport 0000:00:07.0: pciehp: Slot(3): Card not present
snd_hda_codec_hdmi hdaudioC2D0: Unable to sync register 0x4f0800. -5
snd_hda_codec_hdmi hdaudioC2D0: HDMI: invalid ELD buf size -1
i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=io+mem:owns=io+mem
pci 0000:04:00.0: Removing from iommu group 23
pci 0000:04:00.1: Removing from iommu group 23
pci_bus 0000:04: busn_res: [bus 04] is released
pci 0000:03:01.0: Removing from iommu group 23
pci_bus 0000:03: busn_res: [bus 03-04] is released
pci 0000:02:00.0: Removing from iommu group 22
thunderbolt 1-0:3.1: retimer disconnected
thunderbolt 1-3: device disconnected
pcieport 0000:00:07.3: pciehp: Slot(6): Link Down
pcieport 0000:00:07.3: pciehp: Slot(6): Card not present
pcieport 0000:7e:04.0: Unable to change power state from D3hot to D0, device inaccessible
pcieport 0000:7e:04.0: Runtime PM usage count underflow!
xhci_hcd 0000:7f:00.0: remove, state 1
usb usb6: USB disconnect, device number 1
usb 6-1: USB disconnect, device number 2
usb 6-1.2: USB disconnect, device number 3
xhci_hcd 0000:7f:00.0: xHCI host controller not responding, assume dead
wlan0: authenticate with b0:4e:26:9f:4a:de
wlan0: send auth to b0:4e:26:9f:4a:de (try 1/3)
usb 6-1.3: USB disconnect, device number 4
usb 6-1.3.4: USB disconnect, device number 5
usb 6-1.3.4.1: USB disconnect, device number 6
wlan0: authenticated
wlan0: associate with b0:4e:26:9f:4a:de (try 1/3)
wlan0: RX AssocResp from b0:4e:26:9f:4a:de (capab=0x1011 status=0 aid=3)
wlan0: associated
wlan0: Limiting TX power to 23 (23 - 0) dBm as advertised by b0:4e:26:9f:4a:de
IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
xhci_hcd 0000:7f:00.0: USB bus 6 deregistered
usb usb5: USB disconnect, device number 1
usb 5-1: USB disconnect, device number 2
usb 5-1.3: USB disconnect, device number 3
usb 5-1.3.1: USB disconnect, device number 4
usb 5-1.3.2: USB disconnect, device number 5
usb 5-1.3.2.2: USB disconnect, device number 7
usb 5-1.3.4: USB disconnect, device number 6
usb 5-1.3.4.2: USB disconnect, device number 8
xhci_hcd 0000:7f:00.0: Host halt failed, -19
xhci_hcd 0000:7f:00.0: Host not accessible, reset failed.
xhci_hcd 0000:7f:00.0: USB bus 5 deregistered
pci 0000:7f:00.0: Removing from iommu group 20
pci_bus 0000:7f: busn_res: [bus 7f] is released
pci 0000:7e:02.0: Removing from iommu group 18
pci_bus 0000:80: busn_res: [bus 80-a5] is released
pci 0000:7e:04.0: Removing from iommu group 19
pci_bus 0000:7e: busn_res: [bus 7e-a5] is released
pci 0000:7d:00.0: Removing from iommu group 17
perf: interrupt took too long (4928 > 4901), lowering kernel.perf_event_max_sample_rate to 40500
cros_ec_lpcs cros_ec_lpcs.0: packet too long (3378 bytes, expected 0)
perf: interrupt took too long (6165 > 6160), lowering kernel.perf_event_max_sample_rate to 32400
cros_ec_lpcs cros_ec_lpcs.0: packet too long (15853 bytes, expected 0)
traps: ServiceWorker t[11154] trap invalid opcode ip:5600f98ac8cb sp:7fe3131fdc40 error:0 in chrome[5600f89ca000+9fc8000]
perf: interrupt took too long (7731 > 7706), lowering kernel.perf_event_max_sample_rate to 25800
cros_ec_lpcs cros_ec_lpcs.0: packet too long (2 bytes, expected 0)
ACPI: battery: [Firmware Bug]: (dis)charge rate invalid.
cros_ec_lpcs cros_ec_lpcs.0: packet too long (1792 bytes, expected 0)
Note: I am not completely sure that the Fn
keys were working before I started to unload/unplug, it’s just that I got aware of it after I had undocked the laptop.
Here is the full dmesg -t
