[SOLVED] Is it possible to reset the BMS for 56wh Battery
Hello all! I’m the head of technology for my company and I issue FW13s as the standard issue for all employees. I had an employee spill something on the device which subsequently caused a short that seems to have triggered the fuse for the bq40z50 BMS on the battery. I’ve been able to confirm the laptop is perfectly functional and working well otherwise, and the issue is solely in the battery. I followed a few other threads on here going through installing ectool and checking some things and the battery itself is recognized, but will not accept a charge. I’ve also peeled back the battery paper and confirmed that nothing on the battery board has (visibly) popped and that all the cells are still balanced, and I’m able to manually charge them directly without issue, so the cells are good.
From my reading, it looks like the bq40z50 can theoretically be flashed/reset from the SMbus, but this is where all the available information runs dry. Is anyone aware of a method that could reset the fuse/fault state of the BMS or otherwise wake it up? One note of behavior btw, the laptop will refuse to boot into any OS with the battery attached during boot. It will try, but always shuts off before completing. However, if I boot an OS and attach the battery, it runs stably but does not charge. For example, if I boot into Ubuntu via USB, and plug in the battery after boot, it will show the battery, and SOC seemingly properly (shows 58% and charging) but obviously doesn’t charge.
Also, to be clear, this is for my own personal experience and I am not intending to put this battery back into service just FYI.
The battery is (mostly) sealed, the damage is much more likely to be the charging circuit on your mainboard, like this example. [Solved] - Framework 16 | Battery not accepting charge after water spill - #20 by James3?
I’ve already replaced the battery in that unit and it’s in service without issue. But I can confirm for sure that the battery itself is showing a terminate discharge alarm, and terminate charge alarm via Framework-tools. I can also visibly see a light brown stain on one of the cells, so I can also confirm liquid entered the (poorly) sealed battery casing.
Clean the stain thoroughly with isopropyl alcohol, then use EV2400 or NLBA1 to clear the error. I don’t know the exact process so you would need to search for instructions or consult a repair technician that specializes battery repair.
Edit: the overtemperature alarm is weird, as it shouldn’t alarm at merely 26C, mention this screenshot at the repair shop
I was really hoping there would be a method without requiring additional hardware, but those would definitely work. Hopefully someone has a method, but from everything I’m seeing it’s not likely.
Hacking a battery is very advanced, much harder than using a CH431A to flash the BIOS, the operation of the BMS is gated behind highly technical knowledge and hardware away from the general public.
Sure lol. But I was hoping there was an actual intended method ie not ‘hacking’. It’s just an off the shelf BMS and since we already do have an open source method of communicating with it, it would stand to reason that there at least could be a way to achieve what I’m looking for. I’ve been an micro electronics hobbyist for quite a long time and even did some (no degree) college for electrical engineering and do DIY batteries of all shapes and sizes so a tiny little 4s BMS isn’t that scary lol. The vast majority of BMS I’ve used for other projects have some built in and accessible method of clearing faults, so I was hoping this was possible.
lol I tried
read the manual first
And I really appreciate it! I had already found the need for the keys through the BMS documentation and from ectool. Thank you for engaging and trying to help! Again, I was just hoping/praying there was a known method to do this without literally having to hack it, but it doesn’t looking like that’s going to be the case. Seems a silly thing to not be able to clear a simple fault code. Maybe don’t make it TOO easy lol, but also is a shame so many of these batteries would be going to recycling/waste when they are perfectly good for service.
That being said, I’ll hold onto this battery until I either decide to harvest the cells or buy the proper equipment to try and flash/reset it. Although, even with bqStudio and a EV2400, I suppose it’s most likely still going to need the auth keys so it may just be a non starter.
No, it’s not that simple. Some poor quality batteries might brick the battery intentionally or have a very high false trigger rate, like this example. However ATL is a reputable brand and it’s very unlikely for them to brick them intentionally.
There are some possible explanations that worth consider before attempting a hack.
The circuit might be broken, forcing a battery to use might cause overheating of the damaged circuit, which then ignites the battery.
The temperature sensor is damaged, the BMS can’t read the temperature to reduce charging rate when it’s hot so it declares the battery is broken.
Intermittent connection. This problem may seem comes out of nowhere, the battery fails while everything looks the same. Again the BMS bricks it as the connection issue can cause major problem such as cell unbalancing later.
So for the general public replacing the battery pack is the solution because it’s better safe than sorry. If you want to hack it, you have to make sure the battery absolutely doesn’t have any problem at all and the “bricking” is indeed the very very unlikely false positive case.
For sure, I totally agree that these protections are there for a very good reason and I don’t mean to sound like I didn’t think they are necessary or that they are over zealous. I’m preaching to the choir in the Framework Forums, but I’m just not a fan of not being given the ability to a least be able to troubleshoot and attempt to repair since there are plenty of occasions where one of these flags can be set when the issue it detects is only temporary and shouldn’t necessarily render a battery e-waste. Being able to reset a fault doesn’t disable the protection, so is not inherently unsafe. If the fault still exists after clearing, it would simply re-trigger. Being able to do so would be massively helpful in troubleshooting as well. It would be much easier to determine an actual unrecoverable fault/problem if you are able to observe how what you’re attempting actually affects the output state
You can also use a CP2112 (~10$ on amazon) connected to the SMBus of the battery with the DJI Battery Killer software.
I did this a couple of weeks ago with a Soundboks battery, which also used the bq40z50 BMS.
There is also other software like the “CP2112-Utility” and the “CP2112 Laptop Battery Reader” which I didn’t try yet.
Much of these safeguards are written because of laws, regulations, and excursions. It is one thing to have a LCD or a main card go out. It is a whole different story when the battery and its components have the possibility to go wildly out of control and combust.
People have lost their lives, homes, grounded airplanes, evacuated schools, because a little battery that looked harmless chemically reacted and caused intense smoke and fire.
Much of it is to protect the consumer, and namely the manufacturer whose name is on it because someone wants to be compensated for damage or loss.
Recycle the cells at nearby center or look up where to send them so the materials can be safely disposed of.
