Hey gus, today I just noticed my Framework 13 battery is swelling pretty bad after 1.5 year of regular use.
Originally I thought my touchpad has something wrong because right click sometimes didn’t work. And today when I finally decided to take it apart to check what’s going on, I noticed the battery is swelling like Macbook in the old days.
I never used a Macbook before and personally didn’t encounter a swelling battery on Windows laptops (probably because battery outlive the hardware lol), but is it normal after just 1.5 year? I ordered mine last July.
Thanks. Just checked my BIOS is LFK30.03.05 so it’s should be updated since a long time ago, I didn’t remember the last time I update BIOS. I will reach out to support.
Even with the latest BIOS update unplugging and plugging the laptop back in will reset the counter and fully charge the battery again.
If the device regularly lives plugged in all the time, consider limiting the battery charge level permanently to 70%. This will always allow more than enough expansion for excess charge especially when taking the device from a normal climate control and then commuting with it in colder weather.
Many laptops do not have a battery bulging problem if they are not maxed out in their design. The 61Wh battery is pushing the envelope a little more than the stock 55Wh battery did in the same footprint and is a little more sensitive to expanding as a result.
Fortunately, comparted to most laptops, Framework Laptops batteries are easy to change and not costly. Most people get years of service from their batteries but there are some defects that will happen in a shorter period of time.
I have had many generations of Pixel phones and a Gen 3 started to bulge on me a few years after purchasing it. It was just a fluke and the labor to replace it was much more than the cost of the battery. I felt it was just a one off event and have been fortunate to not have an issue since with other models.
I recently had to replace my Framework 13 Trackpad (purchased 7/29/23, received August 8, 2023). I was unable to close the keypad/lid due to the swollen 61W battery. It could have been that the swelling battery was causing my trackpad issues.
Either way, I need a new 61W battery. Unfortunately the 61W new/refurbished batteries are not in stock AND Framework doesn’t know when they will be back in stock. The recommendation from Framework support is to not use/charge the laptop with a swollen battery.
I had applied the BIOS update and kept the battery at lower charging, but the battery swelling in any case. The laptop and battery are out of warranty
So I have an unusable laptop until the 61W battery comes back into stock.
ebay seems to have some Framework 13 batteries for sale (price is high though).
Perhaps check on the forums for nearly-new 55Wh units that people pulled out to swap for the 61Wh units.
It could take a while before these come back in stock, given the turmoil in world supply chains/logistics/raw materials.
A lot of (non-Framework) parts I took for granted as always being available were quietly pulled due to tariffs or the trade wars. I went to re-order them and couldn’t find any suppliers at all, OR the way to get them was via a high minimum order quantity or a drastically increased per-unit price.
UPDATE: I found another website that claims to have the 61Wh battery in stock for around $65. Not sure if it’s legit. I’ve never bought from them before and cannot recommend for or against them.
The laptop 13 should be able to be used in standalone mode without a battery temporarily. It just no longer would be portable and powered on its own. I understand that is not the solution being sought out, though it can work temporarily until a replacement battery is sourced.
Lots of things are not as readily available in today’s world from the last few years, this just seems to be the new normal.
