[SOLVED] Quality control concerns, two sets of defective hinges, and other issues
The title of this post is “Quality control concerns”. My concerns about Framework’s quality control have not been solved. If anything, it’s worse. This thread is a record of my experience with Framework.
But FW don’t manufacture the cooler master case, Coolermaster make it, so it is not FW QA that is the problem.
The original concerns that this thread was about are solved. You yourself indicated this, when you marked this thread as solved more than a year ago.
If you have a new issue, you should create a new Community Support thread with that question, rather than reviving an old, unrelated thread. As Amoun noted, there is already a thread for this new issue, in which you have been participating. That would be the correct place for discussion of that issue, so this thread is now closed.
