I have recently received my Framework Laptop 13 Mainboard (Ryzen AI 9 HX 370) that I was looking to use as a home server (ie. no laptop, no battery, no wifi, etc.). I added a new/blank 8TB SSD (WD_BLACK SN850X) and 2x48GB of RAM (Crucial, DDR5-5600 SODIMM). Put it together in the CoolerMaster enclosure. Connected 2 USB-C, 1 HDMI, and 1 Ethernet expansion cards. Plugged it in to power, looking to boot from my Ubuntu server thumbdrive, but sadly, no HDMI output, only alternating red and blue lights on the left and right of the board.
I contacted support and waiting for their reply, but in the meantime, I thought I’d ask here in case others had experienced the same issue.
Since I have no OS on the SSD, no battery (just connected to a power outlet using the Framework charger via the top left USB-C expansion card), and that it doesn’t output anything via HDMI to my monitor, how can I access the BIOS or make any change to it?
Is there a procedure required to make the board work as a server?
Oh I see. lt normally flashes red because you don’t have the cover screwed in (there’s a chassis intrusion switch that when not depressed, causes the lights to flash). Do you still get it to flash blue and red when the cover is on?
oh yeah, the button you can click on the CoolerMaster enclosure. Yes I did. Nothing changes though. It continues to blink red and blue, with nothing else happening.
And after pressing the power button, how long have you let it run like that? What should happen is that the mainboard detects certain components are missing then switches over to standalone mode.
oh my god, that did it (I think)! Thanks @TheTRUEAsian ! Took ~11min, then my monitor turned on with a screen giving me the option to enable standalone mode. I enabled it.
Unfortunately I didn’t have my thumbdrive plugged in this time, so I had to disconnect power and plug the thumbdrive. Upon re-plugging the power, I see the red and blue blinking lights again, so I’m guessing I need to wait another 11min? Will it be like this at every restart?
Is it because I don’t have that tiny battery to store the state of the machine?
Glad to hear you got it working. I believe the CMOS battery isn’t required for the lights to go away (at least for older generations) but support should have more info on that. As for the USB, after it boots, you can plug it in and it’ll be recognized by the BIOS but having it plugged in before boot is fine as well.
