[SOLVED] Where to find Type E to USB 3.0 pinheader adapter?
Hi
I’m in the process of installing the Framework Desktop Mainboard into a mini-ITX case.
In the Guide at Step 24 it shows exactly an adapter that I would need to connect the USB 3.0 Type A at the front of my case.
Does anyone know like an article number or model of such an adaptor? All I can find are Type E to Type C adapters or terminal block adapters or out of stock items or not shipping to me. I checked Delock as they are available almost everywhere in Switzerland but I didn’t find it there either. Is very complicated to search for the term that matches it.
Any hints or recommendations are appreciated.
That’s a tough one! I don’t think microcenter has it, but I found a Newegg listing: Are you a human?
Search term was “usb 3.0 connector 20 pin type e adapter” and it was still kind of buried…
There a lot of exotic stuff in the results if you need anything a little different usb 3.0 connector 20 pin type e adapter | Newegg.com
amazon (20pin usb adapter). there is female/male plug types
Thanks but unfortunately Newegg don’t deliver to Switzerland and don’t share what part it is, for obvious reasons I guess. But I may just send an enquiry to some local stores.
Looks awfully like this: USB 3.1 Type-E Male to USB 19/20 Pin Header Male Adapter Extension Cable for PC DIY
Searching duckduckgo forType E Male to 19/20 Pin Motherboard Header Converter seemed to do the trick for me.
Thanks all, after a lot of research I finally found some that are on sale in Switzerland. If anyone in Europe searches as well, Delock 67130
https://www.delock.com/produkt/67130/merkmale.html
It says it is not suitable for front panels but I guess it means only one port is available and my case has only one Type-A port.
(Discourse pro tip - title [solved] devices aren’t necessary, as the forum software has a solutions mechanism built-in. Mark an answer post as the answer to the question, and this status will be shown in the list view).
Thanks. But I think as this thread is a general discussion topic I don’t see a button as solution (or I am blind). But I thought if someone was just seeing the titles they still don’t need to go in to answer anymore. :slightly_smiling_face:
Oh, good spot - I can’t find it on one of my own topics either. I have asked admins to see if it can be enabled.
edit your first post. and put (solved) in the title. i think that would work
