Fedora + Measured Boot via UKI
Which release version?
44 Plasma
Which kernel are you using?
7.2.11-200.fc44.x86_64
03.09
Which Framework Laptop 12 model are you using? (13th Gen Intel® Core™)
13th Gen Intel
I’m unsure how to reproduce this problem, but my Framework will seemingly not power off half the time. It will show the plymouth shutdown screen, but the screen remains on and the power button is still lit. To fully power if off I have to hold the power button. I am unsure how to reproduce this issue as I can’t tell what conditions cause it to happen. I have not been able to capture a journalctl where I can pinpoint an error.
