It does seem like a pretty clear hardware problem, so it might actually be in the realm of Framework to solve as a warranty case - hope they’ve been receptive and are trying to handle the situation in direct support contact. I suppose it’s mainly just us other users replying here on the forum, so all we can do is a bunch of guessing and random suggestions, while it sounds likely something needs to replaced or at very least reseated inside.
If you’ve bought the DIY version and have bought your own 3rd party memory, you could always flash a bootable USB drive with Memtest, boot from there and run that through if you haven’t already - just to rule out that it isn’t about faulty memory. It doesn’t sound it is though, if something constantly works on battery but not on power, and you’re seeing weird sensor readings.
